Hardmatic HH-300 Series 811- Durometers for Rubber and Plastics
Series 811
Digital / Dial Durometers are suitable for testing the nature of the following materials -natural rubber, neoprene, polyesters, P.V.C., leather, nitrite rubber, wax, vinyl, cellulose acetates, glass polystyrene, etc.
  • Designed in accordance with the ASTM D 2240, ISO868, ISO 7619, DIN 53 505, JIS K 6253, and JIS K 7215 specifications.
  • Units are available in both Shore A and Shore D scales, and will test a wide variety of applications.
  • The Digital Durometer is provided with data hold function, permitting the operator to make an error-free reading on the LCD screen.
  • The Dial Durometer is provided with a peak retaining hand for error-free reading.
    Testing stand applications
    These stands are used to mount Durometers. They allow constant-pressure hardness measurement by pressing the Durometer vertically on a work piece.
  • Anyone can perform repeatable hardness measurement due to fewer possibilities of human error and measurement variations.
  • The supplied weights can be attached directly to a Durometer and allow constant-pressure hardness measurement of large samples for which a stand cannot be used.
  • The supplied weights are used for calibrating the spring tension of Durometers.
DialDigital
Order No811-329-10811-331-10811-333-10811-335-10811-335-11811-337-10811-337-11
ModelHH-329-10HH-331-10HH-333-10HH-335-10HH-335-11HH-337-10HH-337-11
ScaleShore EShore AShore DShore AShore AShore DShore D
Tip Angle 35°±0.25°35°±0.25°30°±0.5°35°±0.25°35°±0.25°30°±0.5°30°±0.5°
IndenterSphere
(Tip diameter: 0.79mm)
Blunt taper
Sharp point
(Tip curvature: 0.1±0.01mm)
Blunt taper
Blunt taper
Sharp point
Sharp point
FunctionsDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining handDigital: Data hold, Zero -setting, SPC output, Power ON/OFF (Power supply: SR44 x 1pc.) Analog Durometer: Peak retaining hand
TypeCompactLong-legLong-legCompactCompactCompactCompact
Dimension 2.3x1.3x 5.7in 56x33.5x144mm2.3x1.3x 7.4in 60x30x195mm2.3x1.3x 7.4in 60x30x195mm2.3x1.3x 5.7in 56x33.5x144mm2.3x1.3x 5.7in 56x33.5x144mm2.3x1.3x 5.7in 56x33.5x144mm2.3x1.3x 5.7in 56x33.5x144mm
Mass300g320g320g300g300g300g300g
