Heightmatic - Series 574-High Precision Height Gage
Series 574
  • Provides resolution of .0001” / 0.001mm on the large LCD readout for accurate measurements.
  • Excellent functionality and easy operation.
  • The standard bi-directional touch-signal probe provides improved efficiency and reliability of measurement for the Heightmatic.
  • Optional carbide-tipped scribers are available.
  • With SPC data output.
Accuracy: Refer to the list of specifications. (excluding quantizing error for digital models)
Repeatability: .0001” / 0.001mm
Resolution: 0.001mm or .0001"/0.001mm
Display: LCD, 6-digit
Power supply: Via AC adapter
Zero-setting, Presetting, Probe tip diameter compensation, -/+ switching, Data hold, Data output, inch/mm conversion
(inch/mm models)
Alarm: Counting value composition error
Standard Accessories
574-007: Touch-Signal Probe
901385: Scriber Clamp
06AEG302JA: AC Adapter
905691: SPC cable (40” / 1m)
905692: SPC cable (80” / 2m)
900322: Swivel clamp for dial test indicator (inch)
953639: Holding bar for swivel clamp (inch)
900258: Carbide-tipped scriber (inch)
145250: ø1mm contact point for touch-signal probe
145251: ø2mm contact point for touch-signal probe
Order No.574-210-1A574-211-1A574-212-1A
Range0-24in 0-600mm0-18in 0-450mm0-12in 0-300mm
Accuracy.0002in.0002in.0002in
Resolution .0001in 0.001mm.0001in 0.001mm.0001in 0.001mm
Mass-32.78lbs-
