Input Tools Series 264-Digimatic Gage/PC Data Input Device
Series 264
  • The input tool is an interface enabling you to easily input measurement data from a Mitutoyo measuring instrument with the digimatic output feature to your PC.
  • An USB keyboard signal conversion input tool, IT-012U converts measurement data to keyboard signals and directly inputs them to cells in off-the-shelf spreadsheet software such as Excel. An RS-232C communication input tool, IT-007R is also available to input data through RS-232C communication.
  • More accurate measurement is possible using an optional foot switch.
      937179T: Foot switch
      939039: Gage selector
      *1:Connecting cable (optional accessory) is required for a connection to a Digimatic measuring tool.
      *2:Cannot be used for computers that use USB keyboard. When using a IBM Think Pad Series, a commercial keyboard adapter is required. When using AT style keyboard, adapter for conversion is required.
Order No264-007264-016
Measuring Tools Required *1Mitutoyo Digimatic measuring tools w/SPC outputMitutoyo Digimatic measuring tools w/SPC output
PC RequirementPC/Laptop Compatible,with RS-232C Interface Connects to RS-232C port on CPU (D-sub 9-pin connector)PC Compatible, (including laptops) with USB 2.0 or 1.1 port
Outside Dimension1.7x.9x2.8in 44x23.5x72mm1.5x.83x2.5in 38x21x64mm
Mass91g 3.256g 2.0
