KLD Counter Series 174-Special Purpose Type with Limit Signal Output
Series 174
  • Counter designed to signal when a linear scale displacement value and a preset limit value coincide.
  • Two types of limit settings are available:2-step (KLD-212) and 4-step (KLD-214).
    • External zero-set box (1 axis): No.936551
    • External load box (1 axis, for the RS-232C output):No.937326
*1: Count range when the minimum reading is 0.001mm: 99999.999 to –9999.999
      Count range when the minimum reading is 0.005mm: 99999.995 to –9999.995
Order No174-146A174-147A
ModelKLD-212KLD-214
Number of axes to be displayed1 axis1 axis
Number of limit values to be set24
Resolution(Changeable according to the parameter)
When AT100 series is connected: 0.05 to 0.0001mm
When AT715 is connected: 0.01 to 0.001mm
OutputRS-232C (provided as standard)RS-232C (provided as standard)
Display7-segment LCD/ 7 digit*17-segment LCD/ 7 digit*1
Power supply voltage120V AC, 60Hz120V AC, 60Hz
Power consumption25 VA25 VA
Operating temp/humidity range0 to 45°C/ 20 to 80%0 to 45°C/ 20 to 80%
Dimensions332 (W)×163 (D)×204 (H) mm332 (W)×163 (D)×204 (H) mm
Mass3.0kg3.1kg
