LSM-5200 Display Unit Series 544
Series 544
Compact Display Unit for real-time Multi-channel Measurement
  • A compact controller which could be used for multi-unit system configurations.
  • Capable of simple connection to a PC via USB.
  • A Panel-mount type display unit designed for the LSM-S series.
  • Analog I/O and RS-232C is standard.
  • Measurement of odd fluted parts, and simultaneous measurement / 2-program function included.
    *1: The measuring range will be 0.1mm to 2mm in the 1 to 255 edge measurement mode or when activating the automatic workpiece detection with 544-531, 544-532.
    Each function has its combination limit.
    *2: The measuring range is 50μm to 2mm when using 544-531, 544-532. For smaller ranges, contact your local Mitutoyo sales office.
    *3: DC24V external power supply (commercial item) is required separately.
Note 1: Cannot be connected to 544-496A.
Note 2: Previous models such as 544-451 cannot be connected.
Note 3: For USB communication with a PC, a dedicated device driver is required. For details, contact your local Mitutoyo sales office.
Order No.544-047
Display9 digits plus 8 digits LED, guide message LED
Segment1 to 7 (1 to 3, transparent) or 1 to 255 edges*1
Averaging methodArithmetic average: from 4 to 2048; Moving average: from 32 to 2048
(Arithmetic average is from 16 to 2048 when using LSM-500S.)
JudgmentSelecting from "target value ± tolerance value" or "lower limit/upper limit".
Measurement modeStandby, Single measurement, Continuous measurement
Statistical analysisCalculation result is output via USB or RS-232C.
External dimensions144 (W)×72 (H)×197.1 (D)mm
Power supply*324V DC±10%, 1.3A or more (AC adapters are optional)
Standard I/FUSB2.0, RS-232C, I/O analog
Operating environment0 to 40°C, RH 35 to 85% (no condensation)
Preservation environments-20 to 70°C, RH 35 to 85% (no condensation)
OthersMeasurement of odd fluted parts, simultaneous measurement, nominal setting, sample setting, selection of unnecessary digits, transparent object measurement*2
Automatic workpiece detection (dimension/position detected)*1, abnormal data elimination, mastering, statistical processing (when using USB, RS-232C), output timer, automatic measurement in edge mode, presetting Note that every function is limited in its combination possibilities. See the user manual for details.
Mass1.4kg
