Laser Scan Micrometer LSM-500S Series 544
Series 544
High Accuracy Non-contact Measuring System
  • Capable of measuring down to 5μm outside diameter*1.
  • Provides ultra-high accuracy of ±0.3μm over the entire measuring range (5μm to 2mm).
  • Ultra-high speed measurement of 3200 scan/sec.
  • Suitable for high-speed lines or in applications subject to vibration.
Model No.LSM-500SLSM-501SLSM-503SLSM-506SLSM-512SLSM-516S
Package No.64PKA11764PKA11864PKA11964PKA12064PKA12164PKA122
Main Unit No.544-532544-534544-536544-538544-540544-542
Applicable display unitLSM-6200LSM-6200LSM-6200LSM-6200LSM-6200LSM-6200
Measuring Range .0002-0.08in 0.005-2mm *1].002-0.4in 0.05-10mm *1].012-1.18in 0.3-30mm *1].04-2.36in 1-60mm *1].04-4.72in 1-120mm *1].04-6.3in 1-160mm *1]
Repeatability.0000012in 0.03um *3].0000016in 0.04um *3].0000044in 0.11um *3].000014in 0.36um *3].000033in 0.85um *3].000055in 1.4um *3]
Positional Error [*2][*5].000016in 0.4um.00002in 0.5um.00002in 1um.00016in 4um.0003in 8um.0003in 8um
Linearity[*2].000012in 0.3µm *4].00002in 0.5µm *4].00004in 1µm *4].00012in 3µm *4].00024in 6µm *4].00028in 7µm *4]
Measuring region.04x.08in 1x2mm.08x.4in 2x10mm.08x.4in 10x30mm.8x2.36in 20x60mm1.2x4.72in 30x120mm1.57x6.3in 40x160mm
Laser scanning rate 2992in/s 76m/s4449in/s 113m/s4449in/s 113m/s17795in/s 452m/s35590in/s 904m/s47480in/s 1206m/s
Protection levelIP64IP64IP64IP64IP64IP64
EnviromentOperation environment
Temperature 0°C to 40°C
Humidity 35%RH to 85%RH without condensation]
Altitude 2000m or less
Storage environment
Temperature -15°C to 55°C
Storage environment
Storage environment
Storage environment
Storage environment
Storage environment
Line DrawingG-37-ld.jpgG-38-ld.jpgG-39-ld.jpgG-40-ld.jpgG-41-ld.jpgG-42-ld.jpg
product manuals
