Linear Gage LGF-High Resolution Standard Dimensions,Robust Series 542
Series 542
Resolution: 0.1 μm
  • 0.1μm resolution type of reliable LGF series gage.
  • Excellent protection against dust and splashing water (IP66) on the factor floor.
  • Rubber boot (spare) For 10mm range models: No.238772
    For 25mm range models: No.962504
    For 50mm range models: No.962505
  • Thrust stem set
    For 10mm range models: No.02ADB680
    Thrust stem: No.02ADB681
    Clamp nut: No.02ADB682
    For 25mm range models: No.02ADN370
    Thrust stem: No.02ADN371
    Clamp nut: No.02ADB692
    * External dimensions are described in the dimensional drawing of the product. * Thrust stem set is a combination of thrust stem and a clamp nut. A special spanner is required for tightening. If using multiple gages, a thrust stem set for each gage and one special spanner are required.
  • Wrench
    For 10mm range models: No.02ADB683
    For 25mm range models: No.02ADB693
  • Extension cable (5m): 902434
  • Extension cable (10m): 902433
  • Extension cable (20m): 902432
  • Air drive unit
For 10mm range models: No.02ADE230
For 25mm range models: No.02ADE250
For 50mm range models: No.02ADE270
* Required air pressure: 0.2 to 0.4MPa
* Spindle extends when air is supplied.
Applicable Counters
542-075A EH-101P
542-071A EH-102P
    *1: When the spindle speed exceeds 400mm/s, an alarm signal will be output. Also, if using a Mitutoyo counter, an error message will be displayed. If using counters made by other companies, please consult your local Mitutoyo office. Note that over-speed error may occur depending on the impact amount when releasing the contact point freely.
    *2: IP Code is a standard which classifies and rates the degree of protection provided against the intrusion of solid objects and water. This may not be applicable depending on the kind of liquid.
Order No.542-181542-182
Measuring Range4in10mm1in25mm
Resolution0.1µm (.000005”)0.1µm (.000005”)
Quantizing error±1 count±1 count
Measuring ForceContact point upwards- 1.0N or less
Contact point horizontal 1.1N or less
Contact point downwards 1.2N or less
Contact point upwards- 4.0N or less
Contact point horizontal 4.3N or less
Contact point downwards 4.6N or less
Position detection methodPhotoelectric linear encoderPhotoelectric linear encoder
Response speed*1400mm/s400mm/s
Output signal90° phase difference, differential squarewave (RS-422A equivalent)
Minimum edge-to-edge interval, 200ns
Output signal pitch0.4µm0.4µm
MassApprox. 310gApprox. 350g
Dust/water resistance*2Equivalent to IP66 (only gage head)Equivalent to IP66 (only gage head)
Stylusø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312ø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5), standard contact point No.901312
Bearing typeLinear ball bearingLinear ball bearing
Output cable length2m (directly extended from the main unit)2m (directly extended from the main unit)
ConnectorPlug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE)Plug: RM12BPE-6PH (HIROSE), Compatible receptacle: RM12BRD-6S (HIROSE)
