Linear Gage LGS-Absolute Series 575
Series 575
Resolution: 10μm
  • ABSOLUTE electrostatic capacitance type encoder makes it possible to maintain the reference point even when the power is switched off.
  • Excellent protection against dust and splashing water (IP66) on the factory floor.
  • Rubber boot: No.238774 (spare)
  • Air drive unit (metric): No.903594
  • Air drive unit (inch): No.903598
  • SPC cable extension adapter: No.02ADF640
  • Extension cable (0.5m): No.02ADD950
  • Extension cable (1m): No.936937
  • Extension cable (2m): No.965014
* When connecting an extension cable, an SPC cable extension adapter is required. (0ZADF640)
Applicable Counters
542-007A EC-101D Counter, 120V
64PKA132 EG-101D
64PKA135 EB-11D
542-072A EH-102D
64PKA138 EV-16D COUNTER
InchMetric
Order No575-313
Measuring Range .5in
Resolution.0005"
Measuring Accuracy (20°C).0008in
Quantizing error±1 count
Measuring ForceContact point upwards- 1.6N or less
Contact point horizontal- 1.8N or less
Contact point downwards- 2N or lessN
Response speedUnlimited (not applicable to scanning measurement)
OutputDigimatic output
Position detection methodABSOLUTE electrostatic capacitance type linear encoder
MassApprox. 190g
Contact Pointø3mm carbide-tipped (fixing screw: M2.5 (P=0.45)×5)
Standard contact point No.901312
Stem Diaø9.52=3/8"
Bearing typeSlide bearing
Dust/water resistanceEquivalent to IP66 (only gage head)
Output cable length2m (directly extended from the main unit)
Operating temperature (humidity) range0 to 40°C (RH 20 to 80%, no condensation)
Storage temperature(humidity) range–10 to 60°C (RH 20 to 80%, no condensation)
