Linear Scales ABS AT300 Series 539 - Standard Type
Series 539
  • ABSOLUTE linear encoder incorporates both our unique electrostatic capacity and photoelectric technology. * Refer to page H-34 "Quick Guide to Precision Measuring Instruments" for details of the principle of the absolute linear scale.
  • Drastically reduced power consumption since there are no backup batteries.
  • Easy operation because no recalibration is required at startup or after a power failure.
  • Suitable for position feedback in machinery requiring high-accuracy, high-speed control.
  • Improved environmental resistance against mechanical vibration and noise.
* The indication accuracy does not include quantizing error. L0: Effective range(mm)
* A wide variety of special orders are available.
Order NoABS AT353ABS AT343ABS AT343AABS AT303ABS AT303A
Applicable systemFANUC Ltd.NC Control unitMitsubishi Electric Corporation MITSUBISHI CNC seriesMitsubishi Electric Corporation MR-J3Amplifiers supporting Mitutoyo ENSIS interfaceAmplifiers supporting Mitutoyo ENSIS interface
Resolution0.05µm0.05µm0.05µm0.05µm0.05µm
Maximum response speed120m/min120m/min120m/min120m/min120m/min
Effective range100 to 3000mm100 to 3000mm100 to 3000mm100 to 3000mm100 to 3000mm
Accuracy (20°C)*(3+3L0/1000)µm, (5+5L0/1000)µm when the effective range is 1600mm or more(3+3L0/1000)µm, (5+5L0/1000)µm when the effective range is 1600mm or more(3+3L0/1000)µm, (5+5L0/1000)µm when the effective range is 1600mm or more(3+3L0/1000)µm, (5+5L0/1000)µm when the effective range is 1600mm or more(3+3L0/1000)µm, (5+5L0/1000)µm when the effective range is 1600mm or more
Protection LevelIP53IP53IP53IP53IP53
