Linear Scales ABS AT500 Series 539 Slim Spar Type
Series 539
  • Slim shape is suitable for space-saving designs.
  • The high-rigidity ABS AT500-S series has vibration resistance, shock resistance and temperature control. The ABS AT500-H series offers excellent temperature control and high accuracy.
  • Scale alarm display LED allows for easy maintenance.
  • Supports the interfaces of various manufacturers, allowing a variety of system configurations.
*1: The exact value is 0.0048828125μm since the 20μm signal is divided by 4096.
ModelAT500-SCABS AT500-HCABS AT500-HL/HR
TypeHigh rigidity typeHigh accuracy typeHigh accuracy type
Resolution0.005µm*1/0.05µm0.005µm*1/0.05µm0.005µm*1/0.05µm
Maximum response speed150m/min (72m/min for the H series whose resolution is 0.005µm)150m/min (72m/min for the H series whose resolution is 0.005µm)150m/min (72m/min for the H series whose resolution is 0.005µm)
Effective range100-2200mm100-1000mm100-350mm
Accuracy (20°C)(3+3L0/1000)µm(2+2L0/1000)µm(2+2L0/1000)µm
Reference point of expansion
influenced by the temperature
fluctuation
Center of the effective measuring lengthCenter of the effective measuring lengthEdge of the effective measuring length
HL: "+" side of the absolute value
HR: "–" side of the absolute value
Protection LevelIP53IP53IP53
literature
