Linear Scales AT113 Series 539-Slim Spar Type
Series 539
  • Slim spar type with unit sectional dimensions of 22×35mm.
  • Connectable to the KA counter, KLD counter or PSU-200.
  • Dimensionally compatible with AT116 linear scale units.
09AAA033A: Extension cable (80” / 2m)
09AAA033B: Extension cable (200” / 5m)
09AAA033C: Extension cable (280” / 7m)
174-183A 2-Axis KA Counter
174-185A 3-Axis KA Counter
Model-AT113
Effective range 4" to 60" / 100 to 1500mm (20 models)
Resolution .001" to .000005" / 0.01 to 0.0001mm
Accuracy (20°C) Standard: (5+5L0/1000)μm, High accuracy: (3+3Lo/1000)
Output signal Two 90° phase-shifted sinusoidal signals
Maximum response speed 120m/min
Signal output pitch 20μm
Scale reference point Output in 50mm pitch
Protection level IP53
Operating temperature 0 to 45°C
* High-precision model AT113F (JIS Class 0, 3+3L0/1000)μm is also available to special order.
* Ultrahigh-precision model AT113S (2+2L0/1000)μm is also available to special order for the effective range 100 to 500mm.
High-AccuracyStandard
Order NoModelEFF RangeSignal Cable Length
539-201-40AT113-100F0-4in 0-100mm140 in / 3m
539-202-40AT113-150F0-6in 0-150mm140 in / 3m
539-203-40AT113-200F0-8in 0-200mm140 in / 3m
539-204-40AT113-250F0-10in 0-250mm140 in / 3m
539-205-40AT113-300F0-12in 0-300mm140 in / 3m
539-206-40AT113-350F0-14in 0-350mm140 in / 3m
539-207-40AT113-400F0-16in 0-400mm140 in / 3m
539-208-40AT113-450F0-18in 0-450mm140 in / 3m
539-209-40AT113-500F0-20in 0-500mm140 in / 3m
539-211-40AT113-600F0-24in 0-600mm140 in / 3m
539-213-40AT113-700F0-28in 0-700mm140 in / 3m
539-214-40AT113-750F0-30in 0-750mm140 in / 3m
539-215-40AT113-800F0-32in 0-800mm140 in / 3m
539-216-40AT113-900F0-36in 0-900mm140 in / 3m
539-217-40AT113-1000F0-40in 0-1000mm200 in / 5m
539-218-40AT113-1100F0-44in 0-1100mm200 in / 5m
539-219-40AT113-1200F0-48in 0-1200mm200 in / 5m
539-220-40AT113-1300F0-52in 0-1300mm200 in / 5m
539-221-40AT113-1400F0-56in 0-1400mm200 in / 5m
539-222-40AT113-1500F0-60in 0-1500mm200 in / 5m
