Linear Scales AT402E Series 539-General-purpose Type
Series 539
  • Ideal for machine tools for heavy cutting, as well as linear motors.
  • Multi-point elastic fixing for excellent vibration resistance (200m/s2), shock resistance (400m/s2) and temperature characteristics.
  • The Absolute Interval Code allows for a simplified, low-cost ABS system.
  • High accuracy of ±2µm (up to 540mm)
Model: AT402E
Effective range 5.6" to 121.6" / 140 to 3040mm (24 models)
Accuracy (20°C)
Effective range: 140 to 540mm: ±2μm
Effective range: 640 to 940mm: ±3μm
Effective range: 1040 to 3040mm: ±3μm/m
Output signal Signal: 1Vp-p differential sinusoidal signal
Differential reference point pulse: Absolute Interval Code compatible
Maximum response speed 120m/min (With sinusoidal signal amplitude of –3dB)
Signal output pitch 20μm
Protection level IP53
Operating temperature 0 to 45°C
Cable configuration
Type A: 3m flying lead cable
Type B: 3m cable with European CNC connectors
Type C: 3m cable with FANUC connectors
Order NoModelEFF range
L0 inch / mm
Cable
539-371-00AT402E-1405.6in/ 140mm(W/O Cable)
539-371-01AT402E-1405.6in/ 140mm(W/Cable A)
539-371-02AT402E-1405.6in/ 140mm(W/Cable B
539-371-03AT402E-1405.6in/ 140mm(W/CableC)
539-373-00AT402E-2409.6in/ 240mm(W/O Cable)
539-373-01AT402E-2409.6in/ 240mm(W/Cable A)
539-373-02AT402E-2409.6in/ 240mm(W/Cable B
539-373-03AT402E-2409.6in/ 240mm(W/CableC)
539-374-00AT402E-34013.6in/ 340mm(W/O Cable)
539-374-01AT402E-34013.6in/ 340mm(W/Cable A)
539-374-02AT402E-34013.6in/ 340mm(W/Cable B
539-374-03AT402E-34013.6in/ 340mm(W/CableC)
539-375-00AT402E-44017.6in/ 440mm(W/O Cable)
539-375-01AT402E-44017.6in/ 440mm(W/Cable A)
539-375-02AT402E-44017.6in/ 440mm(W/Cable B
539-375-03AT402E-44017.6in/ 440mm(W/CableC)
539-376-00AT402E-54021.6in/ 540mm(W/O Cable)
539-376-01AT402E-54021.6in/ 540mm(W/Cable A)
539-376-02AT402E-54021.6in/ 540mm(W/Cable B
539-376-03AT402E-54021.6in/ 540mm(W/CableC)
539-377-00AT402E-64025.6in/ 640mm(W/O Cable)
539-377-01AT402E-64025.6in/ 640mm(W/Cable A)
539-377-02AT402E-64025.6in/ 640mm(W/Cable B
539-377-03AT402E-64025.6in/ 640mm(W/CableC)
539-378-00AT402E-74029.6in/ 740mm(W/O Cable)
539-378-01AT402E-74029.6in/ 740mm(W/Cable A)
539-378-02AT402E-74029.6in/ 740mm(W/Cable B
539-378-03AT402E-74029.6in/ 740mm(W/CableC)
539-379-00AT402E-84033.6in/ 840mm(W/O Cable)
539-379-01AT402E-84033.6in/ 840mm(W/Cable A)
539-379-02AT402E-84033.6in/ 840mm(W/Cable B
539-379-03AT402E-84033.6in/ 840mm(W/CableC)
539-380-00AT402E-94037.6in/ 940mm(W/O Cable)
539-380-01AT402E-94037.6in/ 940mm(W/Cable A)
539-380-02AT402E-94037.6in/ 940mm(W/Cable B
539-380-03AT402E-94037.6in/ 940mm(W/CableC)
539-381-00AT402E-104041.6in/ 1040mm(W/O Cable)
539-381-01AT402E-104041.6in/ 1040mm(W/Cable A)
539-381-02AT402E-104041.6in/ 1040mm(W/Cable B
539-381-03AT402E-104041.6in/ 1040mm(W/CableC)
539-382-00AT402E-114045.6in/ 1140mm(W/O Cable)
539-382-01AT402E-114045.6in/ 1140mm(W/Cable A)
539-382-02AT402E-114045.6in/ 1140mm(W/Cable B
539-382-03AT402E-114045.6in/ 1140mm(W/CableC)
539-383-00AT402E-124049.6in/ 1240mm(W/O Cable)
539-383-01AT402E-124049.6in/ 1240mm(W/Cable A)
539-383-02AT402E-124049.6in/ 1240mm(W/Cable B
539-383-03AT402E-124049.6in/ 1240mm(W/CableC)
539-384-00AT402E-134053.6in/ 1340mm(W/O Cable)
539-384-01AT402E-134053.6in/ 1340mm(W/Cable A)
539-384-02AT402E-134053.6in/ 1340mm(W/Cable B
539-384-03AT402E-134053.6in/ 1340mm(W/CableC)
539-385-00AT402E-144057.6in/ 1440mm(W/O Cable)
539-385-01AT402E-144057.6in/ 1440mm(W/Cable A)
539-385-02AT402E-144057.6in/ 1440mm(W/Cable B
539-385-03AT402E-144057.6in/ 1440mm(W/CableC)
539-386-00AT402E-154061.6in/ 1540mm(W/O Cable)
539-386-01AT402E-154061.6in/ 1540mm(W/Cable A)
539-386-02AT402E-154061.6in/ 1540mm(W/Cable B
539-386-03AT402E-154061.6in/ 1540mm(W/CableC)
539-387-00AT402E-164065.6in/ 1640mm(W/O Cable)
539-387-01AT402E-164065.6in/ 1640mm(W/Cable A)
539-387-02AT402E-164065.6in/ 1640mm(W/Cable B
539-387-03AT402E-164065.6in/ 1640mm(W/CableC)
539-388-00AT402E-174069.3in/ 1740mm(W/O Cable)
539-388-01AT402E-174069.3in/ 1740mm(W/Cable A)
539-388-02AT402E-174069.6in/ 1740mm(W/Cable B
539-388-03AT402E-174069.6in/ 1740mm(W/CableC)
539-389-00AT402E-184073.6in/ 1840mm(W/O Cable)
539-389-01AT402E-184073.6in/ 1840mm(W/Cable A)
539-389-02AT402E-184073.6in/ 1840mm(W/Cable B
539-389-03AT402E-184073.6in/ 1840mm(W/CableC)
539-390-00AT402E-204081.6in/ 2040mm(W/O Cable)
539-390-01AT402E-204081.6in/ 2040mm(W/Cable A)
539-390-02AT402E-204081.6in/ 2040mm(W/Cable B
539-390-03AT402E-204081.6in/ 2040mm(W/CableC)
539-391-00AT402E-224089.6in/ 2240mm(W/O Cable)
539-391-01AT402E-224089.6in/ 2240mm(W/Cable A)
539-391-02AT402E-224089.6in/ 2240mm(W/Cable B
539-391-03AT402E-224089.6in/ 2240mm(W/CableC)
539-392-00AT402E-244097.6in/ 2440mm(W/O Cable)
539-392-01AT402E-244097.6in/ 2440mm(W/Cable A)
539-392-02AT402E-244097.6in/ 2440mm(W/Cable B
539-392-03AT402E-244097.6in/ 2440mm(W/CableC)
539-393-00AT402E-2640105.6in/ 2640mm(W/O Cable)
539-393-01AT402E-2640105.6in/ 2640mm(W/Cable A)
539-393-02AT402E-2640105.6in/ 2640mm(W/Cable B
539-393-03AT402E-2640105.6in/ 2640mm(W/CableC)
539-394-00AT402E-2840113.6in/ 2840mm(W/O Cable)
539-394-01AT402E-2840113.6in/ 2840mm(W/Cable A)
539-394-02AT402E-2840113.6in/ 2840mm(W/Cable B
539-394-03AT402E-2840113.6in/ 2840mm(W/CableC)
539-395-00AT402E-3040121.6in/ 3040mm(W/O Cable)
539-395-01AT402E-3040121.6in/ 3040mm(W/Cable A)
539-395-02AT402E-3040121.6in/ 3040mm(W/Cable B
539-395-03AT402E-3040121.6in/ 3040mm(W/CableC)
line drawings literature
