Linear Scales ST24 Series 579-Standard Type
Series 579
  • Outputs 2-phase square and sinusoidal wave signals at 10μm pitch.
  • Has a thinner detector head (thickness 11mm).
  • The maximum effective measurement range of 3000mm enables use on large machines.
  • Two types available for each signal output specification.
  • LED function for indicating signal errors.
*1: Effective range / Accuracy
300mm or less/ ±1μm
500mm or less/ ±2μm
1000mm or less/ ±3μm
3000mm or less/ ±3μm/m
*2: Maximum response speed when the sinusoidal signals are output
ModelST24
Detection methodReflective photoelectlic linear encoder
Output signalST24B: 2-phase square wave signals, Alarm reset input
ST24C: 2-phase square wave signals, 2-phase sinusoidal signals
Main scale grating pitch20µm
Signal output pitch10µm
Effective range10 to 3000mm
Resolution0.01, 0.02, 0.05, 0.1µm
Accuracy (20°C)*1±1µm, ±2µm, ±3µm(/m)
Maximum response speed*21200mm/s
Scale reference pointCenter point (10 to 80mm)
50mm pitch (100 to 3000mm)
Power supply voltageDC5V ±5%
Operating temperature/ humidity range0 to 40°C/ 20 to 80% (no condensation)
Storage temperature/ humidity range–20 to 60°C/ 20 to 80% (no condensation)
Head cable length1m (high-flex connecting cable)
