Linear Scales ST46-EZA Series 579-Compact Type
Series 579
  • Includes an automatic adjusting function for the signal (EZA function) at the push of a button.
  • Detector head mounting and signal adjustment possible without oscilloscope or PC.
  • A setup indicator for checking signal strength is included.
  • I/F circuit integrated in connector shell reduces volume to 60% compared to conventional interface.
  • Self-diagnosis function with USB connectivity facilitates signal strength checking and parameter setup.
  • Glass and metal tape scales are available.
  • The thickness of the detector head is only 7.5 mm. The metal tape scale type has a mounting surface area of 12.5 by 9.325 mm, allowing use in applications where a space-saving design is important.
  • Drawings are available on request
ModelST46-EZAST46-EZA
Detection methodReflective photoelectlic linear encoderReflective photoelectlic linear encoder
Scale typeGlassMetal tape
Main scale grating pitch20µm20µm
Output signalType B: 2-phase square wave signals, reference point pulse, external reset input.
Type C: 2-phase square wave signals, reference point pulse, 2-phase sinusoidal signals.
Effective range10 to 3000mm10 to 3000mm
Resolution0.05µm to 5 µm0.05µm to 5 µm
Accuracy (20°C)Effective range 10 to 300mm: ±1µm
Effective range 350 to 500mm: ±2µm
Effective range 600 to 1000mm: ±3µm
Effective range 1100 to 3000mm: ±3µm/m
Effective range 10 to 1000mm: ±5µm
Effective range 1100 to 3000mm: ±5µm/m
(The above accuracy applies to individual
scales. For double-end fixing designs, perform
point-to-point correction after ensuring the
metal tape is tensioned correctly.)
Maximum response speed2.6m/s (With sinusoidal signal amplitude of -3dB)2.6m/s (With sinusoidal signal amplitude of -3dB)
Scale reference point50mm pitch, 10 to 80mm: Center point50mm pitch, 10 to 80mm: Center point
Power supply voltage5VDC±5%5VDC±5%
Operating temperature/ humidity range0 to 40°C, RH 20 to 80% (no condensation)0 to 40°C, RH 20 to 80% (no condensation)
Storage temperature/ humidity range–20 to 60°C, RH 20 to 80% (no condensation)–20 to 60°C, RH 20 to 80% (no condensation)
