Linear Scales Series AT112-F 539-Super Slim Spar Type
Series 539
  • Super slim spar type with unit sectional dimensions of 15.4×30mm.
  • Connectable to the KA counter, KLD counter or PSU-200.
09AAA033A: Extension cable (80” / 2m)
09AAA033B: Extension cable (200” / 5m)
09AAA033C: Extension cable (280” / 7m)
Model: AT112-F (High Accuracy)
Effective range: 1.5" to 40" / 50 to 1020mm (19 models)
Resolution: .001 to .000005" / 0.01mm to 0.0001mm
Accuracy: (20°C) (3+3L0/1000)μm
Output signal Two 90° phase-shifted sinusoidal signals
Maximum response speed: 50m/min
Signal output pitch: 20µm
Scale reference point Output in 50mm pitch*1
Protection level: IP53
Operating temperature: 0 to 45°C
* Ultra-high precision model AT112S (2+2L0/1000)μm is also available to special order for the effective range 50 to 320mm.
*1: Models whose effective range is 50mm or 70mm: Center point Models whose effective range is 120mm or more: 50mm pitch starting at a point 35mm from the " " mark on the left seen from the front.
High-Accuracy
Order NoModelEFF RangeSignal Cable Length
539-251-10AT112-50F0-1.5in 0-50mm120 in / 3m
539-252-10AT112-70F0-2.5in 0-70mm120 in / 3m
539-253-10AT112-120F0-4.5in 0-120mm120 in / 3m
539-254-10AT112-170F0-6.5in 0-170mm120 in / 3m
539-255-10AT112-220F0-8.5in 0-220mm120 in / 3m
539-256-10AT112-270F0-10.5in 0-270mm120 in / 3m
539-257-10AT112-320F0-12.5in 0-320mm120 in / 3m
539-258-10AT112-370F0-14.5in 0-370mm120 in / 3m
539-259-10AT112-420F0-16.5in 0-420mm120 in / 3m
539-260-10AT112-470F0-18.5in 0-470mm120 in / 3m
539-261-10AT112-520F0-20in 0-520mm120 in / 3m
539-262-10AT112-570F0-22in 0-570mm120 in / 3m
539-263-10AT112-620F0-24in 0-620mm120 in / 3m
539-264-10AT112-670F0-26in 0-670mm120 in / 3m
539-265-10AT112-720F0-28in 0-720mm120 in / 3m
539-266-10AT112-770F0-30in 0-770mm120 in / 3m
539-267-10AT112-820F0-32in 0-820mm120 in / 3m
539-268-10AT112-920F0-36in 0-920mm120 in / 3m
539-269-10AT112-1020F0-40in 0-1020mm120 in / 3m
