Linear scale ABS ST1300 Series 579
Series 579
High-speed, high-resolution Absolute Tape Scale
  • 12m maximum effective length, 8-m/s max. response speed and 1nm minimum resolution.
  • Extensive interface compatibility. See specifications below.
  • Outstanding robustness against contamination compared to earlier photoelectric types by using a new detection principle.
  • Choice between double-sided tape and tension mounting methods.
  • Signal validation program facilitates mounting adjustment and maintenance.
  • Applicable Interfaces: FANUC; Mitsubishi Electric; Yaskawa Electric; Panasonic; Mitutoyo ENSIS standard interface
  • Any scale size drawings are available on request.
ModelABS ST1300
Rangemax. 12 m
Accuracy10 µm/m (± 5µm)
Maximum response speed8 m/s (Varies according to the interface)
Min. resolution1 nm / 10 nm
Scale SpecificationsMetal tape
Applicable InterfacesFANUC; Mitsubishi Electric; Yaskawa Electric; Panasonic; Mitutoyo ENSIS standard Interface
