MACH KO-GA-ME SERIES 360-Inline CNC CMM
Series 357
Mitutoyo Ko-ga-me® is a compact, 3D CNC measuring system that can be flexibly configured to almost any process. Can be used in standalone applications or integrated into work cells. If required, the system can measure workpiece features that exceed the Ko-game’s X stroke by mounting the workpiece, or the Ko-ga-me, on an auxiliary X axis. Ideal for inspection of large or small workpieces and offers a wide choice of measuring probes including touch-trigger, optical and scanning types. (Note: Probe choice may be restricted, depending on the application.)
ModelKGM12128-B
Order No.357-159
Type3D CNC Flexible Gage
RangeX-4.72" (120mm)
Y-4.72(120mm)
Z-3.14(80mm)
Resolution0.00000078"(0.02µm)
Guide MethodStraight-motion hard bearing
Maximum Drive Speed 3D
aximum Acceleration 3D
13.38”/s (340mm/s)
0.68G (6,750mm/s2)
Mass: main unit61.7lbs (28kg)
Macine Dimensions (WxDXH)15.03"x14.68"x30.90"
(382mmx373mmx785mm)
Measuring AccuracyTP200/SP25:
19-21°C (66.2-69.8°F) (2.0+5.0L/1000)μm
15-25°C (66.2-69.8°F) (2.3+5.7L/1000)μm
10-30°C (50.0-86.0°F) (2.7+6.5L/1000)μm
10-35°C (50.0-95.0°F) (3.0+7.2L/1000)μm
Probing Error
TP200/SP25: 2.0μm
Scanning probing error
SP25: 2.5μm
videos
