MF Series 176- Measuring Microscopes
Series 176
  • Observation with a crisp and high-resolution erect image and a wide field of view.
  • Measuring accuracy that is the highest in its class (and conforms to JIS B 7153)
  • ML series, high-NA objectives that are specially designed for the MF series (long working distance type)
  • Illumination unit (reflected/transmitted) selectable from a high-intensity LED or halogen bulb (selection required)
  • Variable aperture diaphragm (reflected/ transmitted) allows observation measurement while suppressing light diffraction
  • Variety of standardized stages in sizes up to 400×200mm
  • Quick-release mechanism useful for moving the stage quickly when measuring work pieces that are large in size or quantity
  • Coarse/fine feed handles equipped as standard on both sides allow precise focus and observation measurement regardless of handedness
  • High-magnification eyepiece observation up to 2000×
  • Standard measuring microscope that has a wide variety of optional accessories including a Vision Unit and various digital CCD cameras
Optical tube
• Monocular or Binocular (Must Choose)
• 25º depression angle
• 90º broken cross-hair reticle (12AAG836)
• Erect image
• TV Mount 50/50
Observation Image • Erect Image
Observation Type • Bright Field
Eyepiece Lens
• 10x (Included w/Tube)
• 15x (Optional)
• 20x (Optional)
Objective
• Magnification: 3X (Included)
• W.D.: 2.85” (72.5mm); N.A.: 0.9
• Optional: 1x, 5x, 10x, 20x, 50x, 100x
Light Source
• Halogen or LED
(Must Choose)
• Adjustable Aperture Diaphragms
• Light Intensity Infinitely Adjustable
Transmitted
Illumination • Telecentric Illumination
Reflected Illumination • Koehler Illumination
Display Unit
Number of Axis • 2 axes (MF-A Type) or 3 axes (MF-B Type)
Resolution • 0.0001” / 0.00005” / 0.00001”
(0.001 mm / 0.0005 mm / 0.0001 mm)
Functions •Data Output, Axis Linear Compensation,
Metric or English Units, and more
Stage
• Precision Travel (2.2+0.02L)μm Accuracy
• High Accuracy Linear Glass Scales
• Quick Release Floating mode
• Zero Set Button
Power consumption 70W LED, 120W Halogen, 120V AC, 50/60 Hz
Mass
• 1010D - 148 lbs. / 67 kg
• 2010D - 157 lbs. / 71 kg
• 2017D - 326 lbs. / 148 kg
• 3017D - 344 lbs./ 156 kg
• 4020D - 357 lbs. / 162 kg
176-392: Monocular tube with 10X eyepiece
176-393: Binocular tube with 10X eyepiece set
378-866: 10X eyepiece set (view field dia.: 24mm)
378-857: 15X eyepiece set (view field dia.: 16mm)
378-858: 20X eyepiece set (view field dia.: 12mm)
375-043: Protractor eyepiece (10X)
176-313: Digital protractor eyepiece (10X)
375-036-2: 1X objective (W.D.: 61mm, N.A.: 0.03)
375-037-1: 3X objective (W.D.: 77mm, N.A.: 0.09) (std. accessory)
375-034-1: 5X objective (W.D.: 61mm, N.A.: 0.13)
375-039: 10X objective (W.D.: 51mm, N.A.: 0.21)
375-051: 20X objective (W.D.: 20mm, N.A.: 0.42)
375-052: 50X objective (W.D.: 13mm, N.A.: 0.55)
375-053: 100X objective (W.D.: 6mm, N.A.: 0.7)
176-314-1: Slide type nosepiece (2-mount, par focal)
176-314-2: Slide type nosepiece (2-mount, mag. adjusted)
12AAA643: ND2 color filter (transmitted / surface)
12AAA644: ND8 color filter (transmitted / surface)
12AAA645: GIF filter (transmitted / surface) (std. accessory)
12AAA646: LB80 color filter (transmitted / surface)
375-054: 0.5X camera adapter (with C-mount adapter)
970441: C-mount adapter
513667: Halogen bulb (24V, 50W)
12BAB345: Halogen bulb (long life type, 24V, 50W)
176-308: Vibration damping stand
176-309: Mounting stand
375-056: Stage micrometer
12AAA165: Lens cleaning kit
12AAA846: Foot switch
382951: Vinyl cover (standard accessory)
Illumination units
176-367-2A: LED ring illuminator
176-343A: Twin fiber-optics illuminator
176-366A: Ring fiber-optics illuminator
12AAG806: GIF color filter (for fiber-optics illuminator)
12AAG807: LB80 color filter (for fiber-optics illuminator) Fixture and Stage accessories
176-107: Holder with clamp*
172-378: V-block with clamp* (max. work piece dia.: 1” / 25mm)
172-197: Swivel center support* (max. work piece dia.: 3.1” / 80mm)
176-305: Rotary stage with fine feed knob for 1010D/2010D models
176-306: Rotary stage with fine feed knob for 2017D/3017D/4020D models
*Fixture mount adapter (176-310) is required for 2010D models.
Fixture mount adapter (176-304) is required for 2017D/3017D/4020D models.
Order No.176-861-10176-862-10176-863-10176-864-10
Model No.MF-A1010DMF-A2010DMF-A2017DMF-A3017D
XY stage travel range4x4in-100x100mm8x4in-200x100mm8x6.7in-200x170mm6x6.7in-300x170mm
Z-axis travel range6in-150mm6in-150mm8.7in-220mm8.7in-220mm
Focusing methodManual focusing(coarse focusing: 30mm/rev., fine focusing: 0.2mm/rev.)Manual focusing(coarse focusing: 30mm/rev., fine focusing: 0.2mm/rev.)Manual focusing(coarse focusing: 30mm/rev., fine focusing: 0.2mm/rev.)Manual focusing(coarse focusing: 30mm/rev., fine focusing: 0.2mm/rev.)
Measurement methodLinear encoder (2-axis model: X/Y-axis,3-axis model: X/Y/Z-axis)Linear encoder (2-axis model: X/Y-axis,3-axis model: X/Y/Z-axis)Linear encoder (2-axis model: X/Y-axis,3-axis model: X/Y/Z-axis)Linear encoder (2-axis model: X/Y-axis,3-axis model: X/Y/Z-axis)
Resolution (switchable).0001"/.00005"/.00001" / 0.001mm/0.0005mm/0.0001mm.0001"/.00005"/.00001" / 0.001mm/0.0005mm/0.0001mm.0001"/.00005"/.00001" / 0.001mm/0.0005mm/0.0001mm.0001"/.00005"/.00001" / 0.001mm/0.0005mm/0.0001mm
Measuring accuracy (at 20°C)XY-axis:(2.2+0.02L)µm,L = Measuring length(mm) when not loaded, JIS B 7153XY-axis:(2.2+0.02L)µm,L = Measuring length(mm) when not loaded, JIS B 7153XY-axis:(2.2+0.02L)µm,L = Measuring length(mm) when not loaded, JIS B 7153XY-axis:(2.2+0.02L)µm,L = Measuring length(mm) when not loaded, JIS B 7153
Indication accuracy (at 20°C)Z-axis:(5+0.04L)µm,L = Measuring length (mm) (MF-B type)Z-axis:(5+0.04L)µm,L = Measuring length (mm) (MF-B type)Z-axis:(5+0.04L)µm,L = Measuring length (mm) (MF-B type)Z-axis:(5+0.04L)µm,L = Measuring length (mm) (MF-B type)
XY stage top size11x11in 280x280mm14x11in 350x280mm16.1x13.4in 410x342mm20.07x13.4in 510x342mm
Effective glass size7x7in 180x180mm10x6in 250x150mm10.6x9.4in 270x240mm14.5x9.4in 370x240mm
Swiveling function--±5° (left)±5° (left)
Max. stage load22lbs/10kg22lbs/10kg44lbs/20kg44lbs/20kg
Max. work piece height6in 150mm6in 150mm8.7in 220mm8.7in 220mm
Pages: 1    2    3
