MF-U Series 176 High-power Multi-function Measuring Microscopes
Series 176
378-866
: 10X eyepiece set (view field dia.: 24mm) (standard accessory)
378-857: 15X eyepiece set (view field dia.: 16mm)
378-858: 20X eyepiece set (view field dia.: 12mm)
Turret (Nosepiece)
378-018: Adjustable manual BF turret
378-216A: Adjustable power BF turret
176-211: Adjustable manual BF/DF turret
176-212A: Adjustable power BF/DF turret
Filters
378-092: Polarization unit
378-076: DIC unit for 100X, SL80X, SL50X objective
378-078: DIC unit for 50X, SL20X objective
378-079: DIC unit for 20X objective
378-080: DIC unit for 10X, 5X objective
12AAA643: ND2 color filter
12AAA644: ND8 color filter
12AAA645: GIF filter (standard accessory)
12AAA646: LB80 color filter
Camera Mounts
375-054: 0.5X camera adapter (with C-mount adapter)
970441: C-mount adapter
Bulbs
513667: Halogen bulb (24V, 50W)
12BAB345: Halogen bulb (long life type, 24V, 50W)
517181: Halogen bulb (24V, 100W)
12BAD602: High intensity halogen bulb (24V, 100W)
Illumination units
176-315A: Halogen illumination unit (12V, 100W)
176-316A: Halogen illumination unit (12V, 150W)
176-343A: Twin fiber-optics illuminator
12AAG806: GIF color filter (for 176-315)
12AAG807: LB80 color filter (for 176-315)
Fixture and Stage accessories
176-107: Holder with clamp*
172-378: V-block with clamp* (max. workpiece dia.: 1” / 25mm)
172-197: Swivel center support* (max. workpiece dia.: 3.1” / 80mm)
176-305: Rotary stage with fine feed knob for 1010D/2010D models
176-306: Rotary stage with fine feed knob for
2017D/3017D models
*Fixture mount adapter (176-310) is required for 2010D models.
Fixture mount adapter (176-304) is required for 2017D/3017D models.
Order NumberMF-UA1010D
176-871-10
MF-UA2010D
176-872-10
MF-UA2017D
176-873-10
MF-UA3017D
176-874-10
XY stage travel range4x4in
100x100mm
8x4in
200x100mm
8x6.7in
200x170mm
12x6.7in
300x170mm
Z-axis travel range0-6in
0-150mm
0-6in
0-150mm
0-8.7in
0-220mm
0-8.7in
0-220mm
Focusing methodManual focusing
coarse focusing:10mm/rev
fine focusing:0.1mm/rev
Manual focusing
Manual focusing
Manual focusing
Measurement methodLinear encoder
2-axis model:X/Y-axis
3-axis model:X/Y/Z-axis
Linear encoder
Linear encoder
Linear encoder
Resolution (switchable).0001"/.00005"/.00001"
0.001mm/0.0005mm/0.0001mm
Measuring accuracy(at 20 °C)XY-axis(2.2+0.02L)µm
L=Measuring length(mm)
when not loaded
JIS B 7153
when not loaded
JIS B 7153
when not loaded
JIS B 7153
when not loaded
JIS B 7153
Indication accuracy(20 °C)Z-axis:(5+0.04L)µm
Z-axis:(5+0.04L)µm
Z-axis:(5+0.04L)µm
Z-axis:(5+0.04L)µm
Floating functionX and Y axis
with Quick-release mechanism
X and Y axis
X and Y axis
X and Y axis
XY stage top size11x11in
280x280mm
14x11in
350x280mm
16x13.6in
410x342mm
20x13.6in
510x342mm
Effective glass size7.1x7.1in
180x180mm
10x6in
250x150mm
10.6x9.6in
270x240mm
14.6x9.6in
370x240mm
Swiveling function--±5 ̊(left)±5 ̊(left)
Max. stage loading22lbs/10kg44lbs/20kg44lbs/20kg44lbs/20kg
Max.workpiece height6in/ 150mm6in/ 150mm8.7in/ 220mm8.7in/ 220mm
Pages: 1    2    3    4    5
