MZT-500 Series 810
Series 810
Micro Zone Test System
When it comes to evaluating mechanical properties of ultra-small regions of ultrafine specimens, the MZT-500 Series models are exceptionally powerful tools in the fields of research and development and quality control. The MZT-500 can evaluate mechanical properties, which conventional hardness testing machines for fine specimens cannot measure, such as various CVD and PVD-deposited or generated films, including ion-plated films; hardness of ultra-fine crosssections;bonding mechanical properties; and mechanical wear properties of carbon fibers, glass fibers, whiskers, etc.
  • Test data The indentation factor can be obtained, which is related to the hardness value (partially) shown in Martens hardness test (ISO14577) and Young’s modulus. Deformation characteristics in the load, dwell, and unload phases are also obtainable for use in determining properties of the specimen material.
  • Hardness tests such as Vickers and Knoop hardness tests are supported.
  • The balance lever vibration isolation mechanism reduces the effect of external vibrations on measurements.
  • Indenter indentation depth can be measured up to a maximum of 20μm with a resolution of 0.1nm.
  • Test forces between 0.1mN and 1000mN can be applied electromagnetically for evaluation of material properties in submicroscopic areas.
  • Field-compatible form with cover for protection against dust and wind.
Order No.810-813A810-814A
ModelMZT-500LMZT-500P
SBasic system
Data analysis / control device
Manual type XY stage (Travel range 25x25mm)
Basic system
Automatic XY stage (Travel range: 50x50mm)
Test force loading deviceTest force range: 0.1 to 1000mN
Control resolution: 0.916µN
Loading speed: 0.01 to 100mN/s
Indentation depth measurementRange: 0 to 20µm
Resolution: 0.1nm
Range: 0 to 20µm
Resolution: 0.1nm
IndenterType: Bercovich triangular pyramid indenterType: Bercovich triangular pyramid indenter
Sample surface observation methodCamera: 1/3 inch black and white (410,000 pixels)
Objective (monitor magnification): 100X (2500X),
Optional: 10X (250X), 40X (1000X)
Specimen dimensionsMaximum height: 90mm
Maximum depth: 90mm (From the center of the indenter axis)
Test typeIndentation test (with preliminary test force)
Indentation test (without preliminary test force)
Indentation depth setting test, continuous indentation test, repeated indentation test
