Mach-V9106 Series 360-Inline CNC CMM
Series 360
The MACH-3A and MACH-V maximize machining operations by performing in-line or
near-line, high speed coordinate measuring in conjunction with your CNC machine tools.
These high throughput machines can be incorporated right into the manufacturing line and can
provide pre/post machining feedback to your machine tool for machining adjustments.
† This test is not part of Mitutoyo America’s standard A2LA accredited CMM calibration proceedure and is quoted upon request.
ModelMACH V9106
Order No.360-226A
TypeHorizontal Arm
High Speed, In-line
RangeX-35.43" (900mm)
Y-39.36" (1000mm)
Z-23.62" (600mm)
Resolution0.0000039" (0.0001mm)
Guide MethodMechanical bearing on each axis
Maximum Drive Speed 3D
Maximum Acceleration 3D
34.09”/s (866mm/s)
0.88g (8660mm/s2)
Work TableMaterial-Steel
Size-
35.63" x 41.54"
(905mm x 1055mm)
Tappered Insert-M8x1.25mm
WorkpieceHeight-31.49"(800mm)
Weight-150lbs330kg
Mass (including stand and controller)9,105lbs4130kg
Dimension 58.14x115.85x114.17in 1447x2942x2900mm
ISOISO-10360-2:2009 E0,MPE
19-21°C (66.2-69.8°F) (2.5+3.5L/1000)μm
18-22°C (64.4-71.6°F) (2.7+3.8L/1000)μm
TP7/SP25: 15-25°C (59.0-77.0°F) (2.9+4.3L/1000)μm
5-35°C (41.0-95.0°F) (3.6+5.8L/1000)μm
ISO-10360-4 MPETHP/MPTTHP
SP25: 4.0μm/40sec
ISO-10360-5: 2010 PFTU,MPE
TP7: 2.2μm
SP25: 2.2μm
literature
