MeasurLink Process Analyzer-Process Analyzer Professional Edition-64AAB475
Series contentitem
Designed for more robust manipulation of real-time data in a networked environment using advanced features not available in MeasurLink Process Analyzer Lite Edition. It enables quality engineering to slice and dice data in meaningful ways that contribute to quality control initiatives. For larger installations that use different databases, the ability to switch the connection allows an engineer to analyze data from all sources.
Group, Search and Sort data
View data by part, routine, station, year, month, day. Apply saved filters to data and search for specific traceability or serial number criteria.
Merge Data
Combine lot based or just in time collected data to get a bigger picture of process variation and production quality.
Scatter Plots
Perform correlation studies to identify process interactions.
Summary Analysis
Use wizard to view and print a grid with capability and statistical information.
Electronic Signatures
The e-signatures can be applied to runs only in Process Analyzer Professional. When combined with audit trails available in Real-Time, and security is implemented, then MeasurLink provides support for FDA requirements for the medical and pharmaceutical manufacturers.
Filter Data
Robust filtering capabilities are provided. Often, for runs containing a large volume of data, requests are made for subsets of data.
Compare Capability to Traceability
Easily view charts showing the capability of a characteristic based on the traceability, subgroup or time. Compare the capability of machines, for example. The Cpk shows green for exceeding requirements and red for failing.
Order NoDescription
64AAB475MeasurLink® 8 Process Analyzer Professional Edition
