Metric Square Gage Block Set Series 516-Metric Block Set,Long Block Set,Wear Block Set
Series 516
A Square Gage Block can retain stable orientation both longitudinally and laterally. A wide range of application measurements can be made, including cutting tool positioning, angle measurement with a sine bar, taper measurement with a roller, and inspection of depth micrometers.
Metric Block SetMetric Long Block SetMetric Wear Block
Blocks Per SetOrder NoBlocks In SetGradeMaterial
112516-437-261 pc. 1.0005mm block;
9 pcs. 1.001–1.009mm blocksStep of 0.001mm;
49 pcs. 1.01–1.49mm blocksStep of 0.01mm;
49 pcs. 0.5–24.5mm blocks Step of 0.5mm;
4 pcs. 25–100mm blocks Step of 25mm
00Steel
112516-438-261 pc. 1.0005mm block;
9 pcs. 1.001–1.009mm blocks Step of 0.001mm;
49 pcs. 1.01–1.49mm blocks Step of 0.01mm;
0Steel
112516-439-261 pc. 1.0005mm block
AS-1Steel
112516-440-261 pc. 1.0005mm block;
AS-2Steel
103516-441-261 pc. 1.005
49 Blocks=1.01-1.49 Step=0.01
49=0.5-24.5 Step=0.5 4=25-100 Step=25
00Steel
103516-442-261 pc. 1.005
0Steel
103516-443-261 pc. 1.005
AS-1Steel
103516-444-261 pc. 1.005
AS-2Steel
76516-449-261 pc. 1.005mm
49 pcs. 1.01–1.49mm Step of 0.01mm
19 pcs. 0.5–9.5mm Step of 0.5mm
4 pcs. 10–40mm Step of 10mm
3 pcs. 25–100mm Step of 25mm
00Steel
76516-450-261 pc. 1.005mm
0Steel
76516-451-261 pc. 1.005mm
AS-1Steel
47516-457-261 pc. 1.005mm
9 pcs. 1.01–1.09mm Step of 0.01mm
9 pcs. 1.1–1.9mm Step of 0.1mm
24 pcs. 1–24mm Step of 1mm
4 pcs. 25–100mm Step of 25mm
00Steel
47516-458-261 pc. 1.005mm
0Steel
47516-459-261 pc. 1.005mm
AS-1Steel
47516-460-261 pc. 1.005mm
AS-2Steel
32516-465-261 Block=1.005
9 Block=1.01-1.09 Step =0.01
9 Block=1.1-1.9 Step =0.1
9 Block=1-9 Step=1
3 Block=10-30 Step=10
1 Block=60 Step
00Steel
32516-466-261 Block=1.005
9 Block=1-9 Step=1
1 Block=60 Step
0Steel
32516-467-261 Block=1.005
9 Block=1-9 Step=1
1 Block=60 Step
AS-1Steel
32516-468-261 Block=1.005
9 Block=1-9 Step=1
1 Block=60 Step
AS-2Steel
