Micrometer Heads Series 150- Common Type in Middle Size
Series 150
  • Ratchet stop for constant force.
  • Long spindle type is available for a variety of applications.
  • Carbide tipped measuring face.
Graduations: 0.01mm, 0.001mm, .001" or .0001"
Spindle pitch: 0.5mm
Spindle face: Flat with carbide tip* (more than HRA90)
or spherical, lapped surface *Long spindle type: SKS3 (more than HRC60)
Scale surface: Hard-chrome plating
Fixture thickness for clamp nut: 11.5mm
InchMetric
Order NumberImageRangeAccuracy Stem Diameter Stem/Spindle faceRemarks
150-205-0-1in0.0001in0.375inw/clamp nut/Flat(carbide tip)w/vernier (.0001")
150-206-0-1in0.0001in0.375inPlain/Flat(carbide tip)w/vernier (.0001")
150-207-0-1in0.0001in0.375inw/clamp nut/Flat(carbide tip)-
150-208-0-1in0.0001in0.375inPlain/Flat(carbide tip)-
150-213-0-1in0.0001in0.375inPlain/Flat(carbide tip)-
150-214-0-1in0.0001in0.375inw/clamp nut/Flat(carbide tip)-
150-215-0-1in0.0001in0.375inPlain/Flat(carbide tip)w/vernier (.0001")
150-216-0-1in0.0001in0.375inw/clamp nut/Flat(carbide tip)w/vernier (.0001")
150-217-0-1in0.0001in0.375inPlain/Flat(carbide tip)w/o ratchet stop
150-218-0-1in0.0001in0.375inw/clamp nut/Flat(carbide tip)w/o ratchet stop
150-221-0-1in0.0001in0.375inPlain/FlatReverse Reading
150-222-0-1in0.0001in0.375inw/clamp nut/FlatReverse Reading
150-811-0-1in0.0001in0.375inPlain/Spherical(SR4)-
150-812-0-1in0.0001in0.375inw/clamp nut/Spherical(SR4)-
150-831-1-0in0.0001in0.375inPlain/Flat(carbide tip)Reverse Reading
150-832150-832.JPG1-0in0.0001in0.375inw/clamp nut/Flat(carbide tip)Reverse Reading
