Micrometer Heads Series 152-for XY-Stage
Series 152
152-390, 152-389, 152-391, 152-392
  • Non-rotating device is attached to the spindle tip.
  • Floating thimble allows easy zero setting at any spindle position.
  • Bidirectional graduation for easy reading in both directions.
    152-401, 152-402
  • Adjustable spindle can be moved with the thimble held at any position,
    allowing easy zero-setting.
Graduations: 0.005mm, 0.001mm* *vernier reading
Spindle pitch: 1mm
Spindle face: Flat (hardened) or spherical with carbide tip (more than HRA90), lapped surface
Scale surface: White anodized aluminum
InchMetric
Order NumberImageRangeAccuracy Stem Diameter Stem/Spindle faceRemarks
152-391-0-1in±.0001in.709inPlain/Flat (hardened)with non-rotating devicefor Y-axis,Bidirectional grad.
152-392-0-1in±.0001in.709inPlain/Flat (hardened)with non-rotating devicefor X-axis,Bidirectional grad.
