OPTI-FIX Kits Modular Clamping System for Vision Measuring Systems
Series QV
The modular opti-fix clamping system has been developed specifically for optical coordinate measuring systems.
Opti-fix guarantees safe part fixturing during measurement. This functional configuration also makes multiple part measurements considerably easier.
In order to reduce errant reflections of lighting systems and ambient light effects to a
minimum, all important construction elements are anodized in flat-black or matte finish.
ModelOrder No.ImageDescription
Opti-Set StartK551056K551056.jpgFor construction of a simple rail system with a length of 250 mm and for fixturing parts with simple part geometry. 16 parts.
Opti-Set BasicK551057K551057.jpgFor construction of a basic frame with the dimensions of 200 mm x 100 mm and for fixturing parts with simple part geometry. 26 parts.
Opti-Set RotationK551058K551058.jpgFor construction of a basic frame with the dimensions of 250 mm x 200 mm and for fixturing parts that are rotationally symmetric with and without center holes. 23 parts.
Opti-Set AdvancedK551059K551059.jpgFor construction of a basic frame with the dimensions of 400 mm x 250 mm and for fixturing parts with slightly more complex part geometry. 51 parts
Opti-Set ProfessionalK551060K551060.jpgFor construction of a basic frame with the dimensions of 400 mm x 250 mm and for fixturing parts with complex part geometry. The fixturing of parts with a rotational part geometry is also available. 115 parts. With
Opti-Set RoundK550298K550298.jpgWith locating and clamping elements, included adaptor plates for adaptation to the basic frame of the rail system. 18 parts
