Offset Caliper Series 573,536-ABSOLUTE Digimatic and Vernier Type
Series 573
  • Main scale jaw can slide up and down to facilitate measurement of stepped sections. (Hard-to-get-at dimensions such as A, B, C can be accurately measured.)
  • With depth bar.
  • With SPC data output. (series 573)
Accuracy: Refer to the list of specifications. (excluding quantizing error for digital models)
Resolution*: 0.01mm or .0005"/0.01mm
Graduation**: 0.05mm
Display*: LCD
Length standard*: ABSOLUTE electrostatic capacitance type linear encoder
Max. response speed*: Unlimited
Battery life*: Approx. 3.5 years under normal use
Function of Digital Model
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
05CZA624:SPC cable with data switch (1m/40”)
05CZA625:SPC cable with data switch (2m/80”)
Order NumberImageRange Accuracy Resolution Mass
573-701573-701.jpg0-6in 0-150mm.001in.0005in 0.01mm168g
573-702573-702.jpg0-8in 0-200mm.001in.0005in 0.01mm198g
573-704573-704.jpg0-12in 0-300mm.0015in.0005in 0.01mm350g
line drawings videos
