Offset Centerline Calipers - Series 573, 536-ABSOLUTE Digimatic and Vernier Type
Series 573
IP67
  • Specially designed for center to center distance measurements on the same and offset planes.
  • Can also measure from edge to center.
  • Hole diameter should be in the range of 1.5mm-10mm (.06"-.4").
  • With SPC data output. (series 573)
Accuracy: Refer to the list of specifications. (excluding quantizing error for digital models)
Resolution*: 0.01mm or .0005"/0.01mm
Graduation**: 0.05mm
Display*: LCD
Length standard*: ABSOLUTE electrostatic capacitance type linear encoder
Max. response speed*: Unlimited
Battery life*: Approx. 3.5 years under normal use
Function of Digital Model
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
05CZA624:
SPC cable with data switch (1m/40”)
05CZA625: SPC cable with data switch (2m/80”)
Order NoImageRange Accuracy Resolution Mass
573-705-.4-6in 10-150mm.0015in.0005in 0.01mm157g
573-706-.4-8in 10-200mm.0015in.0005in 0.01mm177g
573-708-.4-12in 10-300mm.0015in.0005in 0.01mm320g
