Optional Accessories for Surftest/Formtracer Compatible with Desktop Models
Series 178
3-axis adjustment table
This table helps make the alignment adjustments required when measuring cylindrical surfaces. The corrections for the pitch angle and the swivel angle are determined from a preliminary measurement and the Digimatic micrometers are adjusted accordingly. A flat-surfaced workpiece can also be leveled with this
Order No.ImageModelDescription
12AAG17512AAG175.jpg-Calibration Stand
12AAM10012AAM100.jpg-Calibration Stand
12AAM30912AAM309.jpg-Calibration Stand
172-142172-142.jpgCenter supportMax.workpiece diameter:120mm
60mm riser is optional (172-143)
172-143172-143.jpgCenter support riserUsed with a center support.
Max. workpiece diameter:240mm
172-144172-144.JPGRotary viseOne-slide jaw type
Max. workpiece size:ø60mm
Minimum reading:5°
172-197172-197.JPGSwivel center supportMax. workpiece diameter:80mm*
*65mm when swiveled 10°
Max. workpiece length:140mm
172-234172-234.jpgV-Block with ClampMax workpiece dia:50
Max workpiece dia:25mm
172-378172-378.jpgV-Block with ClampMax workpiece dia:50
176-107176-107.jpgHolder with clampUsed with cross-travel or rugged table
Max.workpiece height:35mm
178-016178-016.jpgLeveling tableTable top: 130 x 100mm
Leveling range: ±1.5°
Height: 40mm
178-019178-019.jpgPrecision viseMax workpiece size:36mm
Can be mounted on leveling table
178-042-1 (mm)178-042.JPGDigital Leveling tableTable top: 130 x 100mm
XY travel: ±12.5mm
178-043-1(mm)178-043.JPGLeveling table(mm)Table top:130x100mm
Leveling range:±1.5°
XY travel:±12.5mm
178-047178-047.jpgThree-axis adjustment table-
178-052-1 (inch)-Digital Leveling Table-
178-053-1(inch)178-043.jpgLeveling tableTable top:130x100mm
XY travel:±12.5mm
218-001218-001.jpgCross-travel table(mm)Table top:280x180mm
XY travel:100x50mm
218-003218-003.JPGRotary viseTwo-slide jaw type.
Max.workpiece size ø60mm
Min.reading1º
218-011218-001.JPGCross-travel table (in)Table top:280x180mm
XY travel:100x50mm
218-041218-041.JPGCross-travel table(mm)Table top:280x152mm
XY travel:50x25mm
218-051218-041.jpgCross-travel table(in)Table top:280x152mm
XY travel:50x25mm
998291998291.jpgV-blockWorkpiece dia:1mm-160mm
