Optional Styli for Surface Roughness Measurement
Compatible with: SJ-410, SJ-500, SV-2100, SV-3100,SV-3000CNC, SV-M3000CNC, SV-C3200, SV-C4500 Series
Order No. Description
12AAE882STANDARD STYLUS TIP ANGLE 60°/ TIP RADIUS (1µm)
12AAE924STANDARD STYLUS TIP ANGLE 90°/ TIP RADIUS (1µm)
12AAC731STANDARD STYLUS TIP ANGLE 60°/ TIP RADIUS (2µm)
12AAB331STANDARD STYLUS TIP ANGLE 90°/TIP RADIUS 2µm
12AAB403STANDARD STYLUS TIP ANGLE 90°/ TIP RADIUS (5µm)
12AAB415STANDARD STYLUS TIP ANGLE 90°/ TIP RADIUS (10µm)
12AAE883STANDARD STYLUS TIP RADIUS (250µm)
12AAC732SMALL HOLE STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB404SMALL-HOLE STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB416SMALL-HOLE STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAC733EXTRA SMALL HOLE STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB405EXTRA SMALL HOLE STYLUS/TIP ANGLE 90° TIP RADIUS(5µm)
12AAB417EXTRA SMALL HOLE STYLUS/TIP ANGLE 90° TIP RADIUS(10µm)
12AAC734EXTRA MINUTE HOLE STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB406EXTRA MINUTE HOLE STYLUS/TIP ANGLE 90° TIP RADIUS(5µm)
12AAB418EXTRA MINUTE HOLE STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAC740FOR DEEP HOLE 2X-LONG STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB413FOR DEEP HOLE 2X-LONG STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB425FOR DEEP HOLE 2X-LONG STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAC741FOR DEEP HOLE 3X-LONG TYPE STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB414FOR DEEP HOLE 3X-LONG TYPE STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB426FOR DEEP HOLE 3X-LONG TYPE STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAE8982X STYLUS FOR LONG DEEP HOLE /TIP ANGLE 60° TIP RADIUS (2µm)
12AAE9142X STYLUS FOR LONG DEEP HOLE /TIP ANGLE 90° TIP RADIUS (5µm)
12AAE892FOR SMALL HOLE 2X STYLUS FOR LONG DEEP HOLE /TIP ANGLE 60° TIP RADIUS (2µm)
12AAE908FOR SMALL HOLE 2X STYLUS FOR LONG DEEP HOLE /TIP ANGLE 90° TIP RADIUS (5µm)
12AAE884FOR SMALL HOLE/TIP RADIUS (0.8mm)
12AAJ662FOR ULTRA SMALL HOLE/TIP RADIUS (0.25mm)
12AAE938FOR SMALL SLOTTED HOLE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE940FOR SMALL SLOTTED HOLE/TIP ANGLE 90° TIP RADIUS (5µm)
12AAC735DEEP GROOVE STYLUS (10mm) /TIP ANGLE 60° TIP RADIUS (2µm)
12AAB409DEEP GROOVE STYLUS (10mm) /TIP ANGLE 90° TIP RADIUS (5µm)
12AAB421DEEP GROOVE STYLUS (10mm) /TIP ANGLE 90° TIP RADIUS (10µm)
12AAC736DEEP GROOVE STYLUS (20mm) /TIP ANGLE 60° TIP RADIUS (2µm)
12AAB408DEEP GROOVE STYLUS (20mm) /TIP ANGLE 90° TIP RADIUS (5µm)
12AAB420DEEP GROOVE STYLUS (20mm) /TIP ANGLE 90° TIP RADIUS (10µm)
12AAC737DEEP GROOVE STYLUS (30mm) /TIP ANGLE 60° TIP RADIUS (2µm)
12AAB407DEEP GROOVE STYLUS (30mm) /TIP ANGLE 90° TIP RADIUS (5µm)
12AAB419DEEP GROOVE STYLUS (30mm) /TIP ANGLE 90° TIP RADIUS (10µm)
12AAB339GEAR TOOTH STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB410GEAR TOOTH STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB422GEAR TOOTH STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAB338ROLLING CIRCLE WAVINESS SURFACE/TIP RADIUS (0.8mm)
12AAC738KNIFE EDGE DETECTOR STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB411KNIFE EDGE DETECTOR STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB423KNIFE EDGE DETECTOR STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAC739ECCENTRIC ARM STYLUS/TIP ANGLE 60° TIP RADIUS (2µm)
12AAB412ECCENTRIC ARM STYLUS/TIP ANGLE 90° TIP RADIUS (5µm)
12AAB424ECCENTRIC ARM STYLUS/TIP ANGLE 90° TIP RADIUS (10µm)
12AAE893DEEP GROOVE (20mm)/ 2X LONG FOR DEEP HOLE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE909DEEP GROOVE (20mm)/ 2X LONG FOR DEEP HOLE/TIP ANGLE 90° TIP RADIUS (5µm)
12AAE895DEEP GROOVE (40mm)/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE911DEEP GROOVE (40mm)/TIP ANGLE 90° TIP RADIUS (5µm)
12AAE894DEEP GROOVE (30mm)/ 2X LONG FOR DEEP HOLE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE910DEEP GROOVE (30mm)/ 2X LONG FOR DEEP HOLE/TIP ANGLE 90° TIP RADIUS (5µm)
12AAE896GEAR TOOTH /2X LONG FOR DEEP HOLE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE912GEAR TOOTH /2X LONG FOR DEEP HOLE/TIP ANGLE 90° TIP RADIUS (5µm)
12AAE886ROLLING CIRCLE WAVINESS/2X LONG FOR DEEP HOLE/TIP RADIUS (0.25mm)
12AAM601CORNER HOLE/2X LONG FOR DEEP HOLE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAM603CORNER HOLE/2X LONG FOR DEEP HOLE/TIP ANGLE 90° TIP RADIUS (5µm)
12AAE899BOTTOM SURFACE/TIP ANGLE 60° TIP RADIUS (2µm)
12AAE915BOTTOM SURFACE/TIP ANGLE 90° TIP RADIUS (5µm)
