Outside Micrometers Series-105 with Extension Anvil Collars
Series 105
  • Wide measuring range with extension anvil collars.
  • 50mm spindle stroke.
  • Supplied with zero-setting standards bar for each range.
  • Square and round pipes are combined for light weight and rigid frame (for models over 1000mm range).
  • Workpiece stopper (for models over 1000mm range).
  • Supplied in a fitted wooden case.
    Accuracy: ±(6+R/75)µm, R=max. range (mm)
    Graduation: 0.01mm
    Flatness: 1.3µm
    Parallelism: (2+R/100)µm, R=max. range (mm)
Metric
Order NoImageRangeExt CollarsMass
105-103-500-600mm50mm5.53g
105-104-600-700mm50mm6.35g
105-105105-105.jpg700-800mm50mm7.17g
105-106-800-900mm50mm7.99g
105-107-900-1000mm50mm8.81g
105-408105-408.jpg1000-1100mm50mm6.37g
105-409-1100-1200mm50mm7.08g
105-410-1200-1300mm50mm7.79g
105-411-1300-1400mm50mm8.5g
105-412-1400-1500mm50mm9.21g
105-413-1500-1600mm50mm10.17g
105-414-1600-1700mm50mm11.13g
105-415-1700-1800mm50mm12.09g
105-416-1800-1900mm50mm13.05g
105-417-1900-2000mm50mm14.01g
105-418-1100-1200mm50mm,100mm13.77g
105-419-1200-1400mm50mm,100mm15.77g
105-420-1400-1600mm50mm,100mm17.91g
105-421-1600-1800mm50mm,100mm20.8g
105-422-1800-2000mm50mm,100mm22.76g
