Outside Micrometers-Series 340,104-with Interchangeable Anvils
Series 340
  • IP65 water/dust protection 340 series models with a range up to 12in/300mm.
  • Wide measuring range with interchangeable anvils.
  • With a Ratchet Stop for constant force.
  • Supplied with zero-setting standards bar for each range.
  • With SPC output (Series 340).
  • Supplied in fitted wooden case.
Accuracy: ±(4+R/75)ìm, R=max. range (mm)
[.00016” ±.00004 (L/3)”] L = Max Range (Inch)
Resolution*: 0.001mm or .0001"/0.001mm
(340-351-10: .00005"/0.001mm)
Graduation**: 0.01mm
Flatness: 0.6µm/.000024” for models up to 300mm/12”
1µm/.00004” for models over 300mm/12”
Parallelism: 2µm/.00008” for models up to 75mm/3”
3µm/.00012” for models up to 150mm/6”
(2+R/100)µm for models over 150mm, R=max.
range (mm)
[.00008” ± .00004 (L/4)”] L= Max range (inch)
Display*: LCD
Dust/Water protection level*: IP65
Function of Digital Model
Zero-setting, Data hold, Preset, Data output, inch/mm
conversion (inch/mm models)
***Function Lock
***2 Presets
***100-300mm/4-12”
05CZA662: SPC cable with data switch (1m / 40”)
05CZA663: SPC cable with data switch (2m / 80”)
InchInch/Metric DigitalMetricMetric Digital
Order NoImageRange Interchg AnvilsMass
104-137104-137.jpg0-6in0,1,2,3,4,5 in1.35kg
104-138104-138.JPG6-12in0,1,2,3,4,5 in2.65kg
104-150-4-8in0,1,2,3 in1.38kg
104-151-8-12in0,1,2,3 in2.22kg
104-162-2-6in0,1,2,3 in1.35kg
104-165104-165.JPG0-2in0,1 in0.32kg
104-201-12-18in0,1,2,3,4,5 in4.69kg
104-202-18-24in0,1,2,3,4,5 in6.51kg
104-203-24-30in0,1,2,3,4,5 in9.95kg
104-204-30-36in0,1,2,3,4,5 in11.87kg
104-205-36-42in0,1,2,3,4,5 in13.68kg
