Point Micrometers - Series 342, 142, 112
Series 342
  • IP65 water/dust protection (Series 342).
  • Pointed spindle and anvil for measuring the web thickness of drills, small grooves, keyways, and other hard-to-reach dimensions.
  • 15 degree and 30 degree measuring points
    are available.
  • The measuring points have approximately 0.3mm / .012” radius.
  • With SPC output (Series 342).
  • With digit counter (Series 142).
  • With a standard bar except 0 - 25mm and 0 - 1” model.
      Resolution*: 0.001mm or .00005"/0.001mm
      Graduation**: 0.01mm or .001"
      Display*: LCD
      Dust/Water protection level*: IP65
      Function of Digital Model Origin-set, Zero-setting, Data hold, inch/mm conversion
      (inch/mm models)
      05CZA662: SPC cable with data switch (1m/40”)
      05CZA663: SPC cable with data switch (2m/80”)
InchInch/MetricMetric
RangeOrder#ImageAccuMassPointType
0-1in112-177112-177.jpg±.00015205g15°No Carbide Tip
1-2in112-178-±.00015305g15°No Carbide Tip
0-1in112-189112-189.jpg±.00015205g15°-
1-2in112-190-±.00015305g15°-
2-3in112-191-±0.00015370g15°-
0-1in112-225112-225.jpg±.00015205g30°No Carbide Tip
1-2in112-226-±.00015305g30°No Carbide Tip
0-1in112-237112-237.jpg±.00015205g30°-
1-2in112-238-±.00015305g30°-
0-1in142-177-±.00015260g15°Mechanical Counter Model
0-1in142-225142-225.jpg±.00015260g30°Mechanical Counter Model
