Precision Lead Screw
Series 04A
  • Mitutoyo manufactures simple and less expensive precision lead screws for precise positioning mechanisms and fine feed mechanisms,in addition to the conventional micrometer heads.
  • Mitutoyo also manufactures screws with special specifications, such as 0.25 mm pitch,as well as those with the standard 0.5 mm feed pitch and with dimensions and forms that meet customer's requirements.
Order No.Model StrokeFeeding PitchStem Diameter Tip Diameter MassOthers
04AZA160AS-6.56.50.56 -0.0083.510gAS type:Flat spindle tip without nut
BS type:Sperical spindle tip with nut
04AZA161BS-6.56.50.56 -0.0083.511gAS type:Flat spindle tip without nut
04AZA162AS-13130.59.5 -0.009527gAS type:Flat spindle tip without nut
04AZA163BS-13130.59.5 -0.009530gAS type:Flat spindle tip without nut
04AZA164AS-25250.510 -0.0096.3561gAS type:Flat spindle tip without nut
04AZA165BS-25250.510 -0.0096.3564gAS type:Flat spindle tip without nut
