Pulse signal interface unit PSU-200 Series 539
Series 539
The PSU-200 splits the sinusoidal signaloutput by Mitutoyo linear scales into a minimum of four and a maximum of 200 divisions, and converts the signal to a square wave signal so that NC feedback systems, measurement control devices, etc., can be used with linear scales in order to achieve highly accurate positioning.
PSU-200
Order No539-005
Model No.PSU-200
Number of Axes1
No. of splits4, 8, 10, 20, 40, 80, 100, 200 (Selectable with the switch)
FunctionsSetting the number of slits, setting the minimum edge interval, and maximum response speed. Detection of broken wires or short circuits and abnormalities (alarm), detection of signal errors (alarm). Power supply voltage low alarm (warning light only), switching between high-impedance mode and alarm signal output mode. Reference position detection light, hysteresis width settings (directly linked to No. of divisions), external alarm reset input (photocoupler), switching directions
Power supply voltage5VDC ± 5%
Current Consumption 200mA
Storage temperature range–20°C to 70°C
Operating temperature range0°C to 40°C
Dimensions160(W)×100(D)×28(H)mm
Mass1.4lbs 620g
