QM-Height Series 518-High Precision ABSOLUTE Digital Height Gage
Series 518
  • Newly developed high accuracy and high resolution ABSOLUTE linear encoder for position detection.
  • Easy reference icon keys.
  • Possible to measure inside/outside diameter via unique process (detect the circle apex and process by tracing measurement).
  • Various types of optional probes are available.
  • Large size LCD with back light.
  • GO/±NG judgment is performed by setting the upper and lower tolerances. If a judgment result is out of tolerance, the display backlighting changes from green to red, so tolerance judgment can be made at a glance.
  • Slider elevation knob (for travel) / wheel (for measurement).
  • With SPC and USB output.
Measuring range*: 0 - 18.3” or 0 - 28.1”
0 - 465mm or 0 - 715mm
Slider stroke: 14” / 350mm or 24” / 600mm
Resolution: .00005” / .0001” / .0002” / 0.001 /0.005mm or 0.001 / 0.005mm
Accuracy at 20°C:
Guiding method: Roller bearing
Drive method: Manual
Length standard: ABSOLUTE electromagnetic induction type linear encoder
Measuring force: 1.5±0.5N
Power supply: AC adapter (06AEG180JA) 120V battery (LR6x4)
Battery operation time: Refer to the list of specifications
* Maximum values are obtained with the probe at the highest position. Any change of the probe orientation
requires the coordinate system be re-zeroed. With the probe in the highest position, minimum measurable height is 4.53”/115mm.
Inch/Metric
Order Number64PKA094A64PKA095A64PKA129A64PKA130A
ModelQMH-14" AQMH-24" AQMH-14" BQMH-24" B
Parts 518-231.pdf
518-233.pdf
518-235.pdf
518-237.pdf
Measuring Range0-14in 0-350mm0-24in 0-600mm0-14in 0-350mm0-24in 0-600mm
Resolution .00005” / .0001” 0.001 / 0.0005mm.00005” / .0001” 0.001 / 0.0005mm /.00005” / .0001” 0.001 / 0.0005mm.00005” / .0001” 0.001 / 0.0005mm
Accuracy±(2.4+2.1L/600)µm L = Measuring length (mm)±(2.4+2.1L/600)µm L = Measuring length (mm)±(2.4+2.1L/600)µm L = Measuring length (mm)±(2.4+2.1L/600)µm L = Measuring length (mm)
Perpendicularity 7µm12µm7µm12µm
Guiding methodRoller bearingRoller bearingRoller bearingRoller bearing
DisplayLCDLCDLCDLCD
Scale typeElectromagnetic inductiontype ABSOLUTE linear encoderElectromagnetic inductiontype ABSOLUTE linear encoderElectromagnetic inductiontype ABSOLUTE linear encoderElectromagnetic inductiontype ABSOLUTE linear encoder
Measuring Force1.5±0.5(N)1.5±0.5(N)1.5±0.5(N)1.5±0.5(N)
Data OutputDigimatic output/USBDigimatic output/USBDigimatic output/USBDigimatic output/USB
Pneumatic floating systemNANAIncludedIncluded
Power SupplyAC adapter battery / (LR6 x 4) Standard accessory / Nickel metal hydride battery (x4)AC adapter battery / (LR6 x 4) Standard accessory / Nickel metal hydride battery (x4)AC adapter battery / (LR6 x 4) Standard accessory / Nickel metal hydride battery (x4)AC adapter battery / (LR6 x 4) Standard accessory / Nickel metal hydride battery (x4)
Battery operation timeApprox. 300 hours (Not using pneumatic floating system)
Approx. 80 hours (Using pneumatic floating system regularly)
Standard AccessoriesStepped probe (05H2A148)
Probe diameter calibration block (12AAA715)
LR6 Battery / AC Adapter (06AEG180JA) 120V
Mass55.16lbs25kg63.93lbs29kg57.32lbs26kg66.14lbs30kg
Dimension (wxdxh)41.85x21.85x18.94in 1063x555x481mm8.27x13.78x40.24in 210x350x1022mm41.85x21.85x18.94in 1063x555x481mm51.02x21.85x18.94in 1296x555x481mm
Main Unit518-231518-233518-235518-237
line drawings videos literature
