QV ACCEL Series 363-CNC Vision Measuring System
Series QV
Moving-bridge type structure
Designed with primary focus on measurement efficiency, the machine adopts a more rigid construction and drives the X and Y axes at 400mm/s (QVACCEL808,ACCEL1010).
The moving-bridge type structure also eliminates the need for a moving stage. This facilitates a more simplified design of the workpiece fixture, resulting in a significant reduction in the man-hours required for fixture fabrication and inspection.
Model No and TypeQV ACCEL 808PROQV ACCEL 1010PROQV ACCEL1212PROQV ACCEL 1517PRO
Image--QV-1212.jpg-
Range X-Axis0-32in 0-800mm0-40in 0-1000mm0-50in 0-1250mm0-60in 0-1500mm
Range Y-Axis0-800in 0-32mm0-1000in 0-40mm0-1250in 0-50mm0-1750in 0-70mm
Range Z-Axis0-6in 0-150mm0-6in 0-150mm0-4in 0-100mm0-4in 0-100mm
Resolution 0.1µm0.1µm0.1µm0.1µm
High-sensitivity CCD cameraBWBWBWBW
Accuracy (20°C 1.0°C)E1xy-(1.5+3L/1000)µm
E1z-(3.0+4L1000)µm
E2xy-(2.5+4L/1000)µm
E1z-(3.0+4L1000)µm
E1xy-(2.2+3L/1000)µm
E1z-(4.0+5L1000)µm
E2xy-(3.5+4L/1000)µm
E1z-(4.0+5L1000)µm
Max.Drive Speed X/Y400
150mm/s
X/Y400
150mm/s
X/Y300
150mm/s
X/Y300
150mm/s
IlluminationSurface-LED,white
Contour-LED,White
PRL-LED,white (4 divisions)
Surface-LED,white
Contour-LED,White
Surface-LED,white
Contour-LED,White
Surface-LED,white
Contour-LED,White
Maganification change systemProgrammable power (1x ,2x ,6x) turretProgrammable power (1x ,2x ,6x) turretProgrammable power (1x ,2x ,6x) turretProgrammable power (1x ,2x ,6x) turret
Stage glass size34.8x37.7in 883x958mm46.7x46.7in 1186x1186mm56.7x56.7in 1440x1440mm67.5x77.5in 1714x1968mm
Dimension58x67.5x62in 1475x1716x1578mm75.3x82x63in 1912x2086x1603mm85.3x92x61in 2166x2340x1554mm96x113x61in 2440x2868x1554mm
Mass5654lbs 2570kg6490lbs 2950kg7920lbs 3600kg9900lbs 4500kg
videos
