QV Hyper SERIES 363 - High-accuracy CNC Measuring System
Series 363
*The measuring accuracy defined under the following conditions:
Programmable Power Turret: 2x Position; Objective Lens: 2.5x (HR or SL); L=Dimension between two arbitrary points (mm)
**Accuracy 3.5+5.5L/1000 for 20 ± 2°C; Accuracy 3.5+6.0L/1000 from 18 to 23°C
Model No.QV Hyper 302 PROQV Hyper 302 (ISO10360-7)QV Hyper 302 (TAF)
Model NameQuick Vision HyperQuick Vision HyperQuick Vision Hyper
Measuring RangeX-11.81in/300mm
Y-7.87in/200mm
Z-7.87in/200mm
X-11.81in/300mm
Y-7.87in/200mm
Z-7.87in/200mm
X-11.81in/300mm
Y-7.87in/200mm
Z-7.87in/200mm
Resoltion / scale unit0.02µm / reflective-type linear encoder0.02µm / reflective-type linear encoder0.02µm / reflective-type linear encoder
Resolution Z scale using Tracking Autofocus (TAF)--0.26µm
CCD CameraB&WB&WB&W
Illumination Unit (LED)Surface-White LED
Contour- White LED
Programmable Ring Light- White LED
Surface-White LED
Contour- White LED
Surface-White LED
Contour- White LED
Max. Drive Speed X/Y/Z-Axis200mm/s200mm/s200mm/s
Measuring AccuracyE1XE1Y-(0.8+2L/1000)µm
E1Z-(1.5+2L/1000)µm
E2XY-(1.4+3L/1000)µm
E1Z-(1.5+2L/1000)µm
EU,MPE (ISO10360-7:2011)-2.5+4L/1000,2.5+4.5L/1000
PF2D,MPE(ISO10360-7:2011)-1.7µm
E1Z-(1.5+2L/1000)µm
Magnification Change SystemProgrammable Power Turret(1x, 2x, 3)Programmable Power Turret (1x, 2x, 3)Programmable Turret (1x, 2x, 3)
Stage glass size15.71x10.67in
399x271mm
15.71x10.67in
399x271mm
15.71x1067in
399x271mm
Max. stage load44lbs 20kg44lbs 20kg44lbs 20kg
Mass of main unit and stand794lbs 360kg794lbs 360kg794lbs 360kg
Pages: 1    2    3
