QuantuMike Series 293-Coolant Proof Micrometer
Series 293
  • Faster measurement with 2mm per rev. instead of the standard 0.5
  • A patented ratchet thimble mechanism helps ensure repeatability
  • A function lock helps prevent error IP-65 protection level
  • Certificate of inspection is provided.
  • With a standard bar except for 0-25mm/0-1" model
Flatness:0.3µm/.000012”
Battery life: Approx. 1.2 years under normal use
(8 months: over 100mm models)
Origin-set, Zero / ABS, Hold, Function lock Auto power on/off ,
Data output (output models),
inch/mm conversion (on inch/metric models only)
05CZA662: SPC cable with data switch (1m/40”)
05CZA663: SPC cable with data switch (2m/80”)
516-529-26 Inspection Gage Block Set
Rectangular Steel Gage Block 10 pc. blocks and 1 pc. optical parallel
516-319-26 Inspection Gage Block Set
Rectangular Cera Gage Block 10 pc. blocks and 1 pc. optical parallel
*without SPC data output
Order NoImageRangeResolutionAccuracy
293-180-30293-180.jpg0-1in .00005in 0.001mm.00005in
293-181-30293-181.jpg1-2in .00005in 0.001mm.00005in
293-182-30293-182.jpg2-3in .00005in 0.001mm.0001in
293-183-30293-183.jpg3-4in .00005in 0.001mm.0001in
293-185-30*293-185.jpg0-1in .00005in 0.001mm.00005in
293-186-30*293-186.jpg1-2in .00005in 0.001mm.00005in
293-187-30*293-187.jpg2-3in .00005in 0.001mm.0001in
293-188-30*293-188.jpg3-4in .00005in 0.001mm.0001in
line drawings product manuals videos literature
