Quick Scope SERIES 359-Manual Vision Measuring Systems
Series QS-L
    • Surface, contour and fiber-optic ring
    light illumination options enable users to
    configure the QS lighting to meet a variety of
    measurement needs.
    • Powerful, Windows®-based QSPAK software
    offers a spectrum of measuring and analysis
    capabilities.
    • Functions include auto-focus, measurement
    playback, one-click edge detection, graphic
    display, 48 different macros and a pattern
    matching function for several common part
    features.
    • Excellent surface observation model for a
    variety of workpieces.
    • 0.1μm resolution and 150mm Z-axis range.
    • Power zoom enables quick magnification
    changes.
    • Fine illumination capability enables lighting
    changes to match workpiece requirements.
    • The quick release system on the stage enables
    instant switching between coarse and fine
    movements.
    • Quick Navigation function enables the user to
    repeat measurements quickly.
QS-L
Model No.QS-L2010ZBQS-L3017ZBQS-L4020ZB
Order No.359-710-1A359-711-1A359-712-1A
Feed mechanismManualManualManual
Observation unitZoom: 0.75X – 5.25X (8X in 7 steps)Zoom: 0.75X – 5.25X (8X in 7 steps)Zoom: 0.75X – 5.25X (8X in 7 steps)
Measuring Range X-Axis0-8in 0-200mm0-12in 0-300mm0-15.7in 0-400mm
Measuring Range Y-Axis0-4in 0-100mm0-6.7in 0-170mm0-8in 0-200mm
Measuring Range Z-Axis0-6in 0-150mm0-6in 0-150mm0-6in 0-150mm
Resolution/Length Standard0.1µm/Linear encoder0.1µm/Linear encoder0.1µm/Linear encoder
Image detecting unit1/2-inch color CMOS camera 3 mega-pixels1/2-inch color CMOS camera 3 mega-pixels1/2-inch color CMOS camera 3 mega-pixels
Digital zoom1x-2x-4x1x-2x-4x1x-2x-4x
Measuring Accuracy*1XY(2.5+20L/1000)?m
Z(5+40L/1000)?m
XY(2.5+20L/1000)?m
Z(5+40L/1000)?m
XY(2.5+20L/1000)?m
Z(5+40L/1000)?m
Stage glass size9.84x5.91in 250x150mm14.57x9.45in 370x240mm17.32x9.45in 440x240mm
Max stage loading22lbs 10kg44lbs 20kg33lbs 15kg
IlluminationSurface: co-axial light, fiber-optic ring light Contour, stage lightSurface: co-axial light, fiber-optic ring light Contour, stage lightSurface: co-axial light, fiber-optic ring light Contour, stage light
Dimensions*225x30x28in 624x769x722mm27x36x33in 682x916x837mm30x37x33in 757x930x837mm
Main unit160lbs 72kg311lbs 140kg321lbs 146kg
Power Consumption160W at max160W at max160W at max
videos literature
