Quick Vision Active Compact CNC Vision Measuring Systems
Series QV
  • High-quality zoom optics with interchangeable lenses
  • High-resolution and high-speed color camera
  • Compact design saves significant space available in two sizes
  • Powerful QVPAK 3D vision software
  • Contact and noncontact measurement
  • Touch-probe retrofittable
  • Programmable LED stage, coaxial and 4-quadrant ring light.
ModelQV ACTIVE 202 TOUCH PROBE
QVT1-L202Z1L-D
QV ACTIVE 404
TOUCHPROBE QVT1-L404Z1L-D
Order No364-109Z364-110Z
Measuring Range X-Axis0-9.84in 0-250mm-15.75in -400mm
Measuring Range Y-Axis0-7.87in 0-200mm-15.75in -400mm
Measuring Range Z-Axis0-5.91in 0-150mm-7.78in -200mm
Resolution0.1 µm0.1 µm
Measuring accuracy E1(X,Y) = (2+3L/1000)
E1(Z) = (3+5L/1000)
E2(X,Y) = (2.5+4L/1000)
E1(Z) = (3+5L/1000)
Max stage loading22lbs 10kg-
Mass265lbs 120kg44lbs 20kg
Illuminations(White LED)
Contour / Coaxial / 4-quadrant ring light
(White LED)
Magnification change systemZoom optical system with 8 positions
(Standard 1.5X magnification lens)
Sensor typeHigh-resolution CMOS color cameraHigh-resolution CMOS color camera
Optional objective lenrs1X and 2X magnification1X and 2X magnification
Factory optionSeries 364 (TP) Touch-Probe optionSeries 364 (TP) Touch-Probe option
videos literature
