Quick Vision WLI Series 363-CNC Video Measuring System with White Light Inferometry
Series 363
• QV WLI can measure coordinates and dimensions and assess micro-3D forms without contact.
• High-accuracy, dual-head vision measuring system equipped with a white light interferometer.
• The white light interferometer uses a high aspect ratio to accurately measure shapes.
• The standard vision measuring function can continuously perform coordinate,
dimension and 3D shape measuring.
*1: WLI head movable. range Measurement of 3D forms with WLI will be within 1 view field.
*2: In standard mode. Applicable to max. 200μm by modifying scan pitch.
Model QV Hyper WLI 302
QV Hyper WLI 302 (ISO10360-7)
QV Hyper WLI 404
QV Hyper WLI 404 (ISO10360-7)
QV Hyper WLI 606
QV Hyper WLI 606 (ISO10360-7)
Measuring Range (XxYxZ)Vision measuring area:
11.81”x7.87”x7.48”
(300×200×190 mm)
WLI measuring area*1:
8.46”x7.87”x7.48”
(215×200×190 mm)
15.75”x15.75”x9.45”
(400×400×240 mm)
12.40”x15.75”x9.44”
(315×400×240 mm)
23.62”x25.59”x8.66”
(600×650×220 mm)
20.58”x25.59”x8.66”
(515×650×220 mm)
WLI optical head unitWLI optical head unit View field (H×V) - 5X lens: approx. 0.64x0.48mm / 10X lens: approx. 0.32×0.24mm / 25X lens: approx. 0.13×0.10mm
Illumination Co-axial Light-Halogen
Repeatability- 2s = 0.08µm
Z-axis scanning range*2- 170µm
Vision optical head unit
Magnification change system : PPT1X-2X-6X
Image detection method: B&W CCD camera
Illumination:
Co-axial Light- White LED
Transmitted Light- White LED
Programmable ring light: White LED
Measuring accuracy:
E1X, E1Y(0.8+2L/1000)μm
E1Z(1.5+2L/1000)μm
E2XY(1.4+3L/1000)μm
EU,MPE (ISO10360-7:2011) 2.5+4L/1000, 2.5+4.5L/1000
PF2D,MPE (ISO10360-7:2011) 1.7µm
Illumination:
Measuring accuracy:
E1Z(1.5+2L/1000)μm
E2XY(1.4+3L/1000)μm
Illumination:
Measuring accuracy:
E1Z(1.5+2L/1000)μm
E2XY(1.4+3L/1000)μm
Resolution0.01µm0.01µm0.01µm
Max.stage loading33lbs 15kg55lbs 25kg77lbs 35kg
GuidanceLinear Motion BearingLinear Motion Hard BearingLinear Motion Hard Bearing
Dimensions(WxDxH)33.82x37.40x63.23in 859x950x 1606mm40.43x55.39x70.11in 1027x1407x 1781mm51.54x78.15x70.55in 1309x1985x 1792mm
Mass (vibration isolator stand included)1080lbs 490kg2557lbs 1160kg1031lbs 2275kg
videos
