Quickmike Series 293-IP-54 ABSOLUTE Digimatic Micrometers
Series 293
  • The Quickmike provides a speedy spindle feed of 10mm/.4” per thimble rotation as compared to the conventional micrometer with 0.5mm/.025” per rotation. Its wide 30mm/1.2” measuring range allows various workpieces with different shapes to be measured quickly.
  • Non-rotating spindle and the new ratchet friction thimble.
  • Speedy spindle feed of 10mm/rev.
  • With absolute linear scale.
  • IP54 dust/water protection (when not connected with data output cable).
  • With SPC data output.
  • With a standard bar to set the origin point (for models with a range over 30mm/1.2”).
Parallelism: 2µm/.00008” for models up to 80mm/3.2” 3µm/.00012” for models up to 105mm/4.2”
Battery life: Approx. 3 years under normal use
(1 year for models over 30mm / 1.2”)
Dust/Water protection level: IP54
Origin-set, Zero-setting, Data hold, Data output, inch/mm conversion (inch/mm models)
937387:SPC cable (1m/40”)
965013:SPC cable (2m/80”)
InchMetric
Order NoImageRangeAccuracy
293-676293-676.gif0-1.2in 0-30.8mm±.0001in
293-677293-677.gif1-2.2in 25.4-55.88mm±.0001in
293-678293-678.gif2-3.2in 50.8-81.28mm±.00015in
293-679293-679.gif3-4.2in 76.2-106.68mm±.00015in
