Ratchet Thimble Micrometer Series-101,102
Series 102
  • Ratchet function works both from the thimble and the speeder,allowing easy one-handed operation.
  • Clearly audible ratchet operation for reassurance that measurement is being performed at constant,preset force.
  • Provided with a Certificate of Inspection.
  • With a standard bar except for 0-25mm and 0-1in models.
  • Supplied in fitted case.
  • Heat-Insulated frame.
Graduation:0.01mm,0.001mm,.001inor.0001in
Flatness:0.6µm/.000024in
Parallelism:2µm/.00008in
Measuring Faces:Carbide tipped
Measuring force:5-10N
*0.001mm reading is obtained with vernier
**.0001in reading is obtained with vernier
InchMetric
Order NoImageRangeAccuracy
101-711101-711.jpg0-1in±.0001in
101-717**101-717.jpg0-1in±.0001in
102-717**102-717.jpg0-1in±.0001in
102-718**102-718.jpg1-2in±.0001in
