SPC Connecting Cables
Series -1
These cables are used to output measurement data from the digimatic gage with the output feature to the digimatic mini processor, digimatic display unit, multiplexer or other device. Cables of one or two meters are available. Note that the shape of connector differs depending on the model.
ORDER NOImageTYPESIZEAPPLICABLE GAGES
02ADF64002ADF640.jpgDigimatic cable extension adapter-DIGIMATIC CABLE EXTENSION ADAPTER-Need 963937 or965014 to the Data Processor
05CZA62405CZA624.jpgWith data out switch type1m / 40inCoolant Proof Caliper500-68X, 500-76X, 500-78X.
Coolant Proof Digimatic scale units 572-61X
05CZA62505CZA625.jpgWith data out switch type2m / 80inCoolant Proof Caliper500-68X, 500-76X, 500-78X.
64AAA01664AAA016.jpgStraight type3m / 120inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Height Gage 570-2XX, 192-6XX, 192-67X
Indicators 575-XXX, 543-6XX, 543-2XX, 543-4XX
Depth Gages 547-21X, 547-25X, 571-2XX
Scale Unit 572-XXX
Thickness Gages 54
64AAA01764AAA017.jpgStraight type5m / 200inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
64AAA020-10 pins type3m / 120inIndicators 543-5XX
MU-Checkers 519-4XX, 519-621A
MU-Gages 179-207, 179-208
Display 542-022-5A, 542-032-5A, 542-036-5A
Display 572-011A, 572-031A
Linear Height 518-314A, 518-315A
Litematic 318-202A, 318-204A
Heightmatic 57X SERIES.
Digi Derm 179-7XX
Hardness Tester (Micro Hardness Type)
64AAA021-10 pins type5m / 200inIndicators 543-5XX
Digi Derm 179-7XX
64AAA026-6 pins type3m / 120inALL MICROMETERS(not for IP65 mics)
Indicators 543-11X, 543-13X, 543-14X, 543-18X,543-17X
Holtest 468-2XX, 468-9XX
Micrometer Head 164-162, 164-172, 350-71X,329-71X
Borematics 568-XXX
Others Mikematic, Quickmike, Bench Mike 121-XXX
64AAA027-6 pins type5m / 200inALL MICROMETERS(not for IP65 mics)
Borematics 568-XXX
64AAA074-With data out switch type3m / 120inALL DIGIMATIC CALIPERS WITH ABSOLUTE ENCODER
Height Gage 570-2XX
Depth Gages 571-2XX
Scale Unit 572-XXX
64AAA075-With data out switch type5m / 200inALL DIGIMATIC CALIPERS WITH ABSOLUTE ENCODER
Height Gage 570-2XX
Depth Gages 571-2XX
Scale Unit 572-XXX
905338-Straight type1m / 40inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 547-3XX, 547-4XX
905409-Straight type2m / 80inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
905689-Back type1m / 40inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
905690-Back type2m / 80inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
905691-Right type2m / 80inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
905692-Right type2m / 80inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
905693-Left type1m / 40inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
905694905694.jpgLeft type2m / 80inAll CALIPERS WITHOUT ABSOLUTE ENCODER
Scale Unit 572-XXX
Thickness Gages 54
936937936937.jpgSPC Cable1m / 40inIndicators 543-5XX
Digi Derm 179-7XX
937387937387.jpg6 pins type1m / 40in ALL MICROMETERS(not for IP65 mics)
Borematics 568-XXX
959149959149.jpgWith data out switch type1m / 40inALL DIGIMATIC CALIPERS WITH ABSOLUTE ENCODER
Height Gage 570-2XX
Depth Gages 571-2XX
Scale Unit 572-XXX
959150959150.jpgWith data out switch type2m / 80inALL DIGIMATIC CALIPERS WITH ABSOLUTE ENCODER
Height Gage 570-2XX
Depth Gages 571-2XX
Scale Unit 572-XXX
965013965013.jpgSPC Cable2m / 80inALL MICROMETERS(not for IP65 mics)
Borematics 568-XXX
965014965014.jpgSPC Cable2m / 80inIndicators 543-5XX
Digi Derm 179-7XX
