Spherical Face Micrometers-Series 395
Series 395
  • IP65 water/dust protection
  • Designed to measure the wall thickness of various tubing.
  • With Rachet Stop for constant force.
  • With SPC output.
  • With a standard bar except 0-25mm and 0-1in model.
  • Supplied in fitted case.
Flatness: 0.6µm/.000024”
Display*: LCD
Dust/Water protection level*: IP65
Function of Digital Model
Origin-set, Zero / ABS, Data hold, Data output,
inch/mm conversion (on inch/metric models only)
05CZA662: SPC cable with data switch (1m/40”)
05CZA663: SPC cable with data switch (2m/80”)
Order No.ImageRangeAccuracyRemarksMassColumn1
395-351-30395-351.jpg0-1in-0-25.4mm.0001inD:59in270gSpherical anvil and flat spindle
395-352-30-1-2in-25.4-50.8mm.0001inD:59in330gSpherical anvil and flat spindle
395-353-30-2-3in-50.8-76.2mm.0001inD:75in470gSpherical anvil and flat spindle
395-354-30-3-4in-76.2-101.6mm.0001inD:79 in625gSpherical anvil and flat spindle
395-371-30395-371.jpg0-1in-0-25.4mm.0001inD:59 in270gspherical anvil & spherical spindle
395-372-30-1-2in-25.4-50.8mm.0001inD:59 in330gspherical anvil & spherical spindle
395-373-30395-373.jpg2-3in-50.8-76.2mm.0001inD:75?470gspherical anvil & spherical spindle
395-374-30395-374.jpg3-4in-76.2-101.6mm.00015inD:79 in625gspherical anvil & spherical spindle
