Spline Micrometers - Series 331,111
Series 331
  • IP65 water/dust protection (Series 331).
  • The anvil and spindle have a small diameter for measuring splined shafts,slots, and keyways.
  • With SPC output (Series 331).
  • With a standard bar except 0-25mm and 0-1” model.
Resolution*: 0.001mm or .00005"/0.001mm
Graduation**:0.01mm,.001" or .0001"
Parallelism:(2+R/100)µm,R=max. range (mm)
[.00008” + .00004” (L/4”)]
L = max. range (inch)
Display*: LCD
Dust/Water protection level*: IP65
Function of Digital Model
Origin-set, Zero-setting, Data hold, Data output, inch/mm
conversion (inch/mm models)
05CZA662: SPC cable with data switch (1m/40”)
05CZA663: SPC cable with data switch (2m/80”)
InchInch/MetricMetric
Order No111-166
Range 0-1in
Accuracy ±.00015in
RemarksType A
Mass205g
Gen Info.0001 in reading is obtained with vernier
