Surftest Extreme SV-M3000CNC Series 178-CNC Surface Measuring Instruments
Series SV-M Series
  • CNC surface roughness measuring tester
  • Automated measurement of large parts‚ such as crank shafts and cylinder heads
  • CNC Surface Roughness Tester that covers measurement of large/heavy workpieces such as engine blocks, crankshafts, etc.
  • In combination with the surface roughness detector rotating unit, S-3000AR (optional),it can perform continuous measurement over the bottom, top and side surfaces of a workpiece.
  • Compatible with the optional large table for supporting a load of 220 lbs (100 kg) or a large è2 table. Enables continuous automatic measurement of large-size workpieces.
  • Suitable for automatic surface roughness measurement on large and heavy workpieces.
  • Employs the column-moving type configuration that is not restricted by workpiece size. This is advantageous for measuring heavy workpieces such as engine blocks, crankshafts, etc.
  • Provides 31.5” (800mm) of Y-axis stroke. This makes it possible to measure multiple profiles on large workpieces.
  • Load table has a self-contained structure to ensure that various size workpieces, jigs, auto-feed devices, etc., are easily accommodated and can be specified, if required, by special order.
*PC stand not included
Model No.SV-M3000CNC
Order No. (100V-120V)178-549-1
X1-axis measuring range7.87in 200mm
Z2-axis column travel range19.7in 500mm
Y-axis travel range31.5in 800mm
a-axis iclination angle-45 ̊ (CCW),+10 ̊ (CW)
