Surftest SJ-210- Series 178-Portable Surface Roughness Tester
Series 178
  • The 2.4-inch color graphic LCD provides excellent readability and an intuitive display that is easy to negotiate. The LCD also includes a backlight for improved visibility in dark environments.
  • The Surftest SJ-210 can be operated easily using the buttons on the front of the unit and under the sliding cover.
  • Up to 10 measurement conditions and one measured profile can be stored in the internal memory.
  • An optional memory card can be used as an extended memory to store large quantities of measured profiles and conditions.
  • Access to each feature can be password-protected, which prevents unintended operations and allows you to protect your settings.
  • The display interface supports 16 languages, which can be freely switched.
  • An alarm warns you when the cumulative measurement distance exceeds a preset limit.
  • The Surftest SJ-210 complies with the following standards: JIS (JIS-B0601-2001, JIS-B0601-1994, JIS B0601-1982), VDA, ISO- 1997, and ANSI.
  • In addition to calculation results, the Surftest SJ-210 can display sectional calculation results and assessed profiles, load curves, and amplitude distribution curves.
Free Software Download
Order No.178-561-01A178-561-02A178-563-01A178-563-02A178-565-01A178-565-02A
Model NoSJ-210SJ-210SJ-210SJ-210SJ-210SJ-210
Image-SJ210-animation.gif----
Drive UnitStandard type
(178-230-2)
Standard type
(178-230-2)
Retractable type
(178-235)
Retractable type
(178-235)
Transverse tracing type
(178-233-2)
(178-233-2)
Detector0.75mN type
(178-296)
4mN type
(178-390)
0.75mN type
(178-296)
4mN type
(178-390)
0.75mN type
(178-387)
4mN type
(178-386)
Display unitCompact type
(178-253A)
Compact type
(178-253A)
Compact type
(178-253A)
Compact type
(178-253A)
Compact type
(178-253A)
Compact type
(178-253A)
Stylus tip radius2µm5µm2µm5µm2µm5µm
Dect measuring force0.75mN4mN0.75mN4mN0.75mN4mN
line drawings literature
