Surftest SV-3200 Series 178 -Surface Roughness Testers
Series SV Series
The Surftest SV-3200 Series provide high-accuracy, high-level analysis
and multi-functionality in measurement of surface roughness.
• Mitutoyo's Surftest SV-3200 Series provides high-accuracy, high-level analysis and multi-functionality in threedimensional analysis and measurement of fine contour, as well as the conventional type surface roughness measurement.
• Peripheral devices such as the auto-leveling table are available to enhance operability and to enable automatic measurement.
• FORMTRACEPAK V5, dedicated dataanalyzing software, is installed. This software allows data management in a consistent format, from the work site to the laboratory.
• Ceramic, which is known for its superb anti-abrasive property, is used as the X-axis drive unit guide. No lubrication of the guide is required.
• High-accuracy glass scales are built-in on X-axis (resolution: 1.97μin (0.05μm) and Z2-axis (column, resolution: 39.4μin (1μm) to ensure high-accuracy positioning.
• The SV-3200 series manifest high-reliability especially in the horizontal roughness parameters (S, Sm), that require highaccuracy of the X-axis travel.
• When equipped with high accuracy Y-axis table and 3D surface analysis software MCubeMap, this offers CNC type capabilities usually performed on Extreme series machines.
• Various optional detector holders such as Crank Rotary type and Manual Rotary type make this versatile for many different applications.
• New optional Digital Automatic Tilt (DAT) function is best suited for workpieces that are too large for leveling tables.
Model NumberSV-3200S4SV-3200H4SV-3200W4SV-3200L4SV-3200S8SV-3200H8
Order Number (inch)178-444-11A178-445-11A178-446-11A178-484-11A178-447-11A178-448-11A
Measuring Force of detector0.75mN0.75mN0.75mN0.75mN0.75mN0.75mN
Measuring Range X-Axis0-4in 0-100mm0-4in 0-100mm0-4in 0-100mm-4in -100mm0-8in 0-200mm0-8in 0-200mm
Vertical travel12in(300mm) power column20in(500mm) power column20in(500mm) power column27.6" (700mm) power column12in power column20in power column
Granite Base Size23.6x17.7in 600x450mm23.6x17.7in 600x450mm39.4x17.7in 1000x450mm39.4x17.7in 1000x450mm23.6x17.7in 600x450mm23.6x17.7in 600x450mm
Main Unit Dimensions29.8x19x38in 756x482x966mm29.8x19x45.9in 756x482x1166mm45.5x19x46.3in 1156x482x1176mm45.5xxin 1156xxmm30.2x19x38in 766x482x966mm30.2x19x46in 766x482x1166mm
Main Unit Weight140kg 308lbs150kg 330lbs220kg 485lbs270kg 595lbs140kg 308lbs150kg 330lbs
Pages: 1    2
literature
